QUOTE(boxsterfan @ Jul 5 2015, 09:06 PM)
Need to see the longs and the hell hole. Without seeing those, impossible to gauge value.
Just looked at them they are both bone dry and have no rust. A but of dust and a few leaves but nothing a quick run with the shop vac and wax cant fix.
QUOTE(wes @ Jul 5 2015, 11:26 PM)
Do something about the streeing wheel cover!
I plan on doing that
QUOTE(euro911 @ Jul 6 2015, 12:25 AM)
What's the scrutiny you're receiving about the bumper tops?
You might try an auto upholstery shop to see if they can match the material on the center armrest and have it redone. Model year 1971 had a special grain in the seat fabric, may not be the easiest material to find these days
The wheels look like early 70's vintage Pacific-Italia Carreras. Not too common on 914s, but seen moreso in the VW arena. They're probably narrow wheels (4.5") that don't allow for tires wider than 175s, maybe 185s at max. The offset is more than likely VW too, so wide tires (especially the rears) would tend to rub against the fender lips. Some folks would roll the lips to allow wider tires if running VW offset wheels. Check the back side to see if they list the size and offset.
The car looks nice in the pix, but as mentioned previously, RUST plays a significant role in assessing value. If you're not familiar with where to look, see if a member here local to you can assist you with that evaluation. There are a few World members who reside in NV.
I was told that the rubber tops is not correct for that year? Also thank you on the Rims. As far as the dash is concerned; I recently took it into an exotic dealer, and was warned against replacing original parts.
QUOTE(Spoke @ Jul 6 2015, 05:10 AM)
The things you mention are bolt-on items (bumper, dash, wheels) which are secondary items of importance when determining the 914's value.
Primary concern is integrity of the chassis. you'll get the bulk of the value of the car from the chassis. Take off the rocker panels under the doors and take pictures of the longitudinals. Take pics of the hell hole; the floor pans under the seats; the front and rear trunk floors; any kind of body rust.
Of importance as well is the engine; does it run? Carbs or FI? Stock or upgraded? Time/miles since the last rebuild if known?
I had it looked over, put on a lift and scrutinized by a specialist and no rust was found anywhere on the body or the frame. Nothing rusts up here anyways. The hell hole and longs have been addressed as no rust. The engine has the original FI set up. And has had 12k on the rebuild.
QUOTE(mepstein @ Jul 6 2015, 06:08 AM)
but if I saw a cracked dash on a 914 I'm thinking $4-5k max just because I'm assuming everything else needs work. A replacement dash from 914rubber is currently $400 and is a pita to install. Need many more pics to hone in on a reasonable sell price.
I have been told by a few dealers and people now that replacing anything original hurts the value.
But the engine is a 1.7L and runs and drives great. TO clarify anyone posting further. I have had 3 different dealers look it over and not a single one of their mechanics could find rust anywhere on the vehicle. The rubber on the vehicle is in great shape as well.
