QUOTE(J/41 @ Jul 6 2015, 10:08 PM)
QUOTE(Ian Stott @ Jul 6 2015, 08:36 PM)
I adjusted the pedals out a bit farther, give that a try before you do anything else, they are designed to do that.
Ian Stott
Moncton
Canada
Hi Ian, I didn't know the pedals were adjustable..where are the adjustments for the pedals located. I just looked under the seat again and I am pretty sure the seat is up all the way. Howevere Maybe tomorrow I can pull the seat out and take a look. I have had several 911's and never with getting the seat up close enough .. this is my first 914. It should be on the road in the next couple of weeks.. I will start working on the interior soon.. New carpet etc. install a radio lube everything.. thanks for your help John G
The only adjustment on the pedals is a slight amount on the clutch pedal. You might get 1/2 adjustment. You could make thick pedal covers for the gas brake and clutch pedals. If you wanted to do something semi permanent I have extra brake and clutch pedals that could be used to fab up adjustable height pedals.
I have some ideas on how that could be done. Or you could get another seat frame and graft on longer rails.
Bruce
Thanks again...I will try that tomorrow Too! jg
The pedals themselves are adjustable, get right down to the pedal cluster and you will see the bolt to back off. I was surprised at what a difference it made, my daughter is 5 foot 1 and she can drive it no problem.
Ian
