While I can't get on with the six resto properly, I can get on with some small jobs so when it comes time to crack on and eventually put everything back together I have either new or restored components ready to fit
I need some thoughts and guidance on restoring the tail lights
I have two complete sets, one off the -6 and one off a panel donor rolling shell
Six buckets are poor and have pulled studs / a few cracks etc. Therefore I will probably use the donors
It might sound crazy but I was thinking about running the rear bucket and lamp reflectors through the dishwasher on a low temp to remove the remaining silvering and give the buckets a good clean prior to other cleaning stages
To make painting reflector and bucket clean easier should I cut the wiring to separate bucket and reflector? Solder / splice and heat shrink to reassemble
Anyone used the chrome spray paint (seems to have mixed reviews) or just paint reflectors bright silver?
Best way / products to clean up the buckets
Gentle warm soapy water only for the lenses presumably
I have some new rubber lense seals etc from 914rubber etc
Six lights had rubber washers fitted to the studs, donor did not. Required or not?
Any other top tips
Thanks
Jon
Donor
Six
