914itis
Jul 7 2015, 12:07 PM
I have an engine of unknown history . As far as I can tell, it was rebuilt at least the heads were changed but not ran since.
It spins freely by with decent resistance. I removed the oil cooler and valve cover, spun it a few times by hands ( at least 10 times) shouldn't I see oil coming out at least from the oil cooler holes ?
stugray
Jul 7 2015, 02:19 PM
If it was never primed after the rebuild, it could take a couple of minutes of cranking (not all at once, the starter wont like that).
Take off the oil filter and see if you can get oil out there first.
zambezi
Jul 7 2015, 09:10 PM
I don't think you will see much oil movement by just turning the engine by hand.
TeenerTech
Jul 7 2015, 10:49 PM
you need to spin it a lot faster to get the oil to move, when we test fire engines it usually gets oil pressure after about four 20 second bursts with the starter. A starter usually spins and engine at roughly 200 RPM.
