mhenderson57
Jul 8 2015, 08:06 AM
I'm looking for a braided stainless steel hose extension to install a oil pressure sending unit on my 2.0 liter engine. I would appreciate any advice on this purchase.
Thanks,
Matt
ChrisFoley
Jul 8 2015, 08:11 AM
I have several on the shelf.
stugray
Jul 8 2015, 11:06 AM
I used a 10mmX1.0 to npt adapter and a grease gun hose extension from FLAPS but many just thread it right in to the case without the adapter.
DavidSweden
Jul 8 2015, 11:14 AM
QUOTE(stugray @ Jul 8 2015, 09:06 AM)
+1, although the grease gun hose is a little stiffer than I would have liked
stugray
Jul 8 2015, 11:26 AM
mine:
Mark Henry
Jul 8 2015, 12:30 PM
BTW if you use the grease gun hose you have to ground the sender unit.
ChrisFoley
Jul 8 2015, 01:12 PM
IMO grease gun hoses don't last long in service.
pete000
Jul 8 2015, 02:14 PM
The trick is how to install it with the engine in the car. I am still trying to figure out how to get a wrench down in there.
Anyone have any pictures of tools they have made or modified to tighten the hose fitting?
Harpo
Jul 8 2015, 04:13 PM
I purchased everything from JEgs this is an Earls pre assembled AN-4 line. The first time I installed the grease gun line I used a 7/16 crows foot tool. When I install this new line I will only need a socket to install the 1/8 to AN-4 adapter
pete000
Jul 8 2015, 04:23 PM
QUOTE(Harpo @ Jul 8 2015, 03:13 PM)
Ah, I will give this a try !
BeatNavy
QUOTE(pete000 @ Jul 8 2015, 04:14 PM)
Yeah, I did mine with the engine out of the car. Doing it with the engine in the car would seem to be a bit of a challenge. But I don't think you want to torque it too much. As Harpo suggested, I think a crows feet socket would be the best bet.
I got mine at AA (I know, I know
). It wasn't a great value and I wish I had known Racer Chris had them. I would have gladly bought it from him instead.
dangerranger01
Jul 8 2015, 05:02 PM
Click to view attachmentWhat is that aluminum colored block in the center for? And is the stock thread 1/8npt?
Do you all run the gauge full time?
stugray
If you use the adapter like in my pic above (brass piece), you can thread that in with a socket.
Then you can reach the hose fitting with an open end.
mr914
Jul 8 2015, 05:17 PM
If you have a Parker store nearby
It's Parker 919 hose. -4AN one side 1/4"FPT the other and a 1/4MPT to -4 male adaptor. 8"hose, or how long you like and they crimp it right there.
Had on made at Christmas time in Rochester and the whole thing ran less than $20
Hose is tough stuff, rated for like 475F
stugray
Jul 8 2015, 06:04 PM
QUOTE(mr914 @ Jul 8 2015, 05:17 PM)
The thread in the case is very close to 1/8" NPT and a 1/8" NPT WILL thread in.
However there is a huge debate about what the thread actually is.
I am of the belief that it is 10mm x 1.0.
The 10mm x 1.0 to 1/8" NPT fit perfectly and then the 1/8 Grease hose threaded into that more than 3 threads.
Mike Bellis
Jul 8 2015, 06:57 PM
The thread pitch (thread spacing really) is the same but the 1/8"NPT is a tapered thread, the 10mm is not tapered.
The 1/8" NPT will thread in and work but is not correct for the metric thread. I do not know of anyone that had a leak or thread failure using the NPT thread.
Jake Raby
Jul 8 2015, 08:48 PM
All you need is the hose from a paintball gun. Its rated to 3,000 PSI and is a braided hose. They ground the sensor, too.
I have had one in service for a decade on my own car. I think it cost 6 bucks last time I bought one.
stugray
Jul 8 2015, 08:57 PM
From the other thread:
QUOTE(LotusJoe @ Apr 25 2013, 01:29 PM)
Dtjaden
Jul 8 2015, 10:14 PM
This is also what I am using.
Valy
Jul 8 2015, 11:49 PM
This will set you up with the adapter from 10mm to NPT, hose and gauge. $25
http://www.harborfreight.com/engine-oil-pr...-kit-98949.html
Harpo
Jul 9 2015, 03:54 AM
The aluminum block is actually "C" channel that will hold the "T" fitting down to the engine. My intent is to copy Stugrey's design. Yes I intend to run with the gauge full time.
QUOTE(dangerranger01 @ Jul 8 2015, 03:02 PM)
