MikeM
Jul 10 2015, 03:48 PM
Hello...I need to break down and buy these. I replaced my bushings 2 years ago with poly but they snap, crackle and pop and I don't like it!!!
Would love to hear from anyone that has installed these. Are you happy with them? Are they noisy? How as the installation, difficult or easy?
Thanks,
Mike
stugray
Jul 10 2015, 03:52 PM
While we are on this subject: I have the stock rubber bushings (new) and they pop a LOT.
What is the most popular lubricant to try to spray/squirt/inject into those to make them stop popping?
I figured WD40 would penetrate the best, but white lithium might be better but harder to get into the crevice.
MikeM
Jul 10 2015, 03:54 PM
I didn't want to hear that!! I thought they were quiet???
brant
Jul 10 2015, 03:56 PM
QUOTE(stugray @ Jul 10 2015, 03:52 PM)
You need to install grease zerks and then channel groves into the bushings on these
MikeM
Jul 10 2015, 04:05 PM
Are you guys talking about front or rear? I'm talking about rear RUBBER bushings.
shoguneagle
Jul 10 2015, 04:15 PM
I have the brass/bronze bushings in the rear as well as the front. I have the ones that have the grease inserts (zeros) and channeled grooves. I do not have many miles on them but they do not make noise.
You can install the rubber/plastic ones from Elephant Racing and groove them. You can install zero fittings in the external holders and apply grease thus making them somewhat silent. How much, I do not know. It has been done in some of the real early build threads. Just make sure the zeros align with the grooves. Rears might be more difficult than the fronts.
I do like the Elephant Racing brass/bronze ones. Fairly easy to but you can break off the zerts when installing the rear suspension. You also have to watch the zert position to make sure it does not interfere with the suspension movement and applying the grease.
The process for inserting grease/zert fittings is the same for either the brass/bronze type or the rubber/plastic type (have to cut groove) type.
Somewhere I have the required drill and male metric tape listed.
Try to do a search and locate the information.
Steve
MikeM
Jul 10 2015, 04:24 PM
A couple of years ago I installed the poly bushings. I carefully followed the honing and fitting instructions and JB welded them into place. I installed the Zerks also.
Now after driving for a while they snap crackle and pop. Very annoying.
I'm hoping the rubber ones will be all quiet.
Mike
pete000
Jul 10 2015, 04:39 PM
I have the Elephant rubber bushings in the front and they are quiet and comfortable. Will be doing the rears soon.
JmuRiz
Jul 10 2015, 07:06 PM
My brother got elephant rubber a around on his 930 recently and loves them. I plan on replacing my front/rear with their product when I put my car back together.
t collins
Jul 10 2015, 07:54 PM
QUOTE(pete000 @ Jul 10 2015, 03:39 PM)
Same here and quiet as a mouse
shane
Jul 10 2015, 10:24 PM
I installed them about a year ago, easy to install and no noise.
MikeM
Jul 11 2015, 11:32 AM
Shane....did you install zerks for grease?
Thanks...
Larmo63
Jul 11 2015, 11:41 AM
I bought an unknown (unmarked) set of rear poly type bushings here on the board for my rears when I did them and there has been no squeaking at all. The arms were powder coated, maybe that helped them stay quiet.
I can't say enough good things about the Elephant rubber fronts. They are a great product. Perfect.
MikeM
Jul 11 2015, 11:55 AM
I must have done something wrong in my installation. Hope the rubber version is the answer. I don't want to do this again!!
Mike
shane
Jul 11 2015, 12:06 PM
QUOTE(MikeM @ Jul 11 2015, 10:32 AM)
Thanks...
No, from my understanding of stock rubber bushing they are suppose to flex (twist) not slip. You use liquid soap to slide them in and the soap dries up and the bushing no longer is free to slip, it flexes when the control arm goes up and down. What ever they are doing mine are not making noise.
Mueller
Jul 11 2015, 12:14 PM
QUOTE(shane @ Jul 11 2015, 11:06 AM)
Thanks...
^this would be my understanding how they work as well....it has been ages since I've taken a suspension apart, but if they are vulcanized to the parts then for sure they are intended to flex for sure.
It seems that one would want to install the parts at darn near exact ride height, ideally this would have the least amount of tension up or down, the rubber could act like a spring and you wouldn't want that.
MikeM
Jul 11 2015, 12:27 PM
Thanks gentlemen...
andys
Jul 11 2015, 02:11 PM
Some years ago, I spoke with the tech guys at Energy Systems, who manufacture lots of polyurethane suspension bushings of all kinds. They advised me that the most effective lubricant for polyurethane bushings is marine grease.
I made Delrin bushings for my trailing arms, and have no issues.
Andys
MJHanna
Jul 11 2015, 03:13 PM
I have them on my 911 race car they have been on there for 5 plus years. I just pulled them and they look like new. (all are the bronze type) They don't squeak or bind up. I will use them on my next project. They are easy to do , the fronts are real easy. On his web site you can pull the instructions and read them before you buy them.
raynekat
Jul 11 2015, 07:39 PM
This is true.
No need to groove or zerk fitting a rubber bushing.
It's not needed or even recommended.
They should be dead quiet and last a number of years.
Elephant Bushing has probably the best set around.
You need to Google their YouTube on installation and their comparison to competitors to get the big picture.
shane
Jul 11 2015, 10:17 PM
Yah I thought about that after I put every thing together with the arm hanging all the way down. I hope the soap was still a little slippery so it set at ride level, how ever seems to be happy.
MikeM
Jul 11 2015, 10:26 PM
Hello...searched you tube but could not find their installation video.
If you have it handy, could you provide a link? Thanks.
altitude411
Jul 12 2015, 09:22 AM
MikeM
Jul 12 2015, 09:24 AM
Thanks...I'm surprised they don't have one specific to the trailing arms.
Mike
