QUOTE(Hine62 @ Jul 13 2015, 08:04 PM)
I followed the wire to the head sensor. I does read between 180 and 210 most of the time.
You're getting results that are just short of nonsense. The fuel injection's CHT sensor has a completely different temperature range than the one for the oil temp gauge, which is the gauge you are showing. Luckily, they do work on the same principle and even in the same direction. (They're both thermistors, they have less resistance when they're hot than when they're cold.)
The stock CHT runs out of resolution right around the time the heads get to working temperature. The sender is in an area of the head whose temp lags pretty badly, as well, so by the time it reacts to a change the operating bits of the head have already heated up or cooled down significantly.
The decent CHT senders use a thermocouple, which generates a small voltage across it depending on the temperature it sees. And the gauge, of course, reads it correctly. And the sender goes under a spark plug, in an area that reacts much more quickly to temp changes.
--DD
