QUOTE(Ferg @ Jul 14 2015, 10:51 AM)
QUOTE(RobW @ Jul 14 2015, 06:07 AM)
Nice! What are you going to do to refresh it?
It's getting torn all the way down... Runs and drives fine now, I suspect I have a valve seat issue on #2, leak down is fine on the all the rest at 4 percent, but #2 is about 8 percent and have a tapping I cannot adjust out. Compression is even at 128 at my altitude of 5500. Uses about one quart per 1k. I have smoke on downshift.
Motor has been done once long ago, but no records, so time to go all in.
Mine had a little smoke on startup, decent compression and leakdown numbers, etc. But, it also had a tapping coming from the left side that got louder as the engine warmed up. Oil pressure dropped as the car warmed up as well. My 2.7 is now undergoing a rebuild...previous rebuilder (before I bought the car) did not thoroughly clean the case so now the oil pump is shot and a couple galleries were partially blocked. Fortunately, the crank and cams are not damaged. I will be getting new pistons and relined cylinders (along with reworked heads and such). My case had already been time-serted. Make sure your block is clean after they are through with machining!
