914bub
Jul 15 2015, 06:34 PM
So yesterday I was under my car working on my exhaust when I looked forward and saw this:
Click to view attachment I am going to add a sway bar so I was thrilled to find out I already had them but I'm wondering why I do? The car is a 72 and there's no evidence of damage in the past that would have made replacing both lower control arms necessary. It also does not have holes as if it had a sway bar and somebody removed it.Tabs are factory welded.
Anybody else run into this?
Not sure why the pic is upside down but you get the idea.
Montreal914
Jul 15 2015, 06:39 PM
My 73 was originally a 1.7 therefore no factory sway bars. My front trailing arm already had the U tabs. It made the installation of the swaybar somewhat easier.
wndsnd
Jul 15 2015, 06:41 PM
Ditto the same for my 73.
However, is that a hole in your A-arm?
Larmo63
Jul 15 2015, 06:44 PM
Yes, that is a hole in his A arm. They all have them, it's the end of the welded bar that gussets the arm.
wndsnd
Jul 15 2015, 06:53 PM
Learn something every day here!
Porschef
Jul 15 2015, 07:39 PM
My 76 has the tabs welded in from the factory. Also made installing the bar much easier. Maybe they gave the young welders somethin to practice on, a big crate of lower control arms with tabs periodically refilled...
Dave_Darling
Jul 15 2015, 10:33 PM
Probably easier to just make more than you need with tabs than to figure out the exact number and make only those.
--DD
914bub
Jul 16 2015, 01:14 PM
QUOTE(Dave_Darling @ Jul 15 2015, 09:33 PM)
--DD
Dave
I hadn't considered the fact that you might have been able to order a sway bar as an option. I knew LE's had them but I thought those were the only cars that came with a sway bar as standard equipment. Did 6's have them? Did "later" cars have them standard? If they were optional for other years any idea how much they cost?
vw505
Jul 16 2015, 02:42 PM
My 73 had tabs, and yes adding the bar was easy.
914Sixer
Jul 16 2015, 03:17 PM
Starting in 75 the U tabs were deleted. However when the 76 production run started, they used all the parts they could find on the shelf. Most 75-76's did not have them.
Old Yella
Jul 16 2015, 05:48 PM
QUOTE(914Sixer @ Jul 16 2015, 02:17 PM)
saw this?
Dave_Darling
Jul 17 2015, 09:20 AM
QUOTE(914bub @ Jul 16 2015, 12:14 PM)
They were standard on the 73 2.0 (with a few exceptions). Optional on all other 73+ 914s. Not sure on the earlier ones, nor on the Sixes.
--DD
maf914
Jul 17 2015, 02:16 PM
My 76 had factory a-arm tabs but no factory sway bar. I added H&H bars, front and rear, many years ago. The front sway bar drop links bolted up directly to the tabs. Very nice handling improvement.
