QUOTE(Larmo63 @ Jul 16 2015, 09:15 AM)
It looks clean, but $9K seems too high. Have an expert do a PPI for you if possible.
I am with Lawrence on this.
Too high and there is more rust that you cant see from the pics. I can see the ground through the floor pan which tells me there may be rust under the pedals. The jack post rust screams rust in the longs and in the hell hole too. Need to check under the battery...always a problem.
As everyone will tell you here, having the rocker panels removed for a closer inspection is very important.
