9fourteen14
Jul 16 2015, 08:46 PM
What type of oil do you use in your 914?
I do have the owner's manual but I am VERY curious to what most 914 owners use?
does anyone use mobile 1 or synthetic? what kind?
BTW: I did do a search and does not seem anyone else has asked this. if so I am sorry.
teener luva
ConeDodger
Jul 16 2015, 09:09 PM
Brad Penn 20W50...
Oh and the topic has been covered quite a lot.
VaccaRabite
Jul 16 2015, 09:10 PM
Tons of oil threads.
most people will use 20w-50 in the summer. Brad Penn or Joe Gibbs.
If you drive in the cold move to a 40wt oil in the frozen months.
Just make sure it has ZDDP.
Zach
mr914
4 or 6?
In the 4, when I had one, I use 20w/50 Castrol GTX on the 90+ summer months. Rest of the time it's 10w-40.
In the 6, I'd use either Mobil1 or Syntec 5w-30 or 40
My thought on synthetic, it's a wonderful oil, keeps oil temps 10 degrees or so cooler, but if you have small leaks, they will become bigger leaks. If you have a leak free motor, synthetic is fine.
ripper911
Jul 17 2015, 05:47 AM
Valvoline VR1 20w-50.
gfg3
Jul 17 2015, 06:02 AM
QUOTE(ripper911 @ Jul 17 2015, 07:47 AM)
Valvoline VR1 20W50
JawjaPorsche
Jul 17 2015, 06:19 AM
QUOTE(gfg3 @ Jul 17 2015, 08:02 AM)
Valvoline VR1 20W50
era vulgaris
Jul 17 2015, 07:08 AM
QUOTE(ConeDodger @ Jul 16 2015, 11:09 PM)
Brad Penn 20W50...
PO of my car (in CA) was using BP 10w40. I switched to BP 20w50 when I did the first oil change after getting the car home. It seemed much happier and sounded much better with the 20w50.
EdwardBlume
Jul 17 2015, 07:13 AM
QUOTE(ConeDodger @ Jul 16 2015, 08:09 PM)
Brad Penn 20W50...
t collins
Jul 17 2015, 07:31 AM
Brad Penn 20w50 in my 2.0L four and Valvoline VR1 20W50 in my 2.4L six
(Brad Penn leaks like crazy in my six)
Mark Henry
Jul 17 2015, 07:32 AM
Chevron Delo 400 Multigrade SAE 15W-40 , cheap and it's what Supertec uses/recomends in their high end /6 builds.
0396
Jul 17 2015, 07:42 AM
Search is your best friend
anderssj
Jul 17 2015, 10:45 AM
QUOTE(JawjaPorsche @ Jul 17 2015, 08:19 AM)
Valvoline VR1 20W50
I ran Rotella 15w40 for years (until they went to service spec CJ-4 and took out the ZDDP), then went to VR-1 20w50. My question is what's the latest recommendation(s) for the transaxle (I'm assuming it's still dino-oil) . . . .
Steve A-
Mark Henry
Jul 17 2015, 12:45 PM
QUOTE(anderssj @ Jul 17 2015, 12:45 PM)
Valvoline VR1 20W50
Steve A-
Delo 400 is about the same as old RotellaT
Trany oil just get cheap dino and spend the coin saved (over expensive oils) on changing it every couple of years.
struckn
Jul 17 2015, 05:53 PM
After a complete engine rebuild in 2013 Translog GT used Brad Penn for Break in Oil and after 500 Miles put SWEPCO 306 15W40 in mine. I've continued using the SWEPCO 306 with no issues at all.
brant
Jul 17 2015, 09:35 PM
Current race tranny is
Redline light weight shock proof.
Significantly better already at racing/high temps of 235
More tranny life already
You should see how sticky this stuff is.... And it's synthetic
Elliot Cannon
Jul 17 2015, 10:22 PM
Mobil 1 15W50. Ceramic lifters.
EdwardBlume
Jul 19 2015, 04:19 PM
Changed the oil in Dad's car. I forgot how green Brad Penn comes out.
mramber
Jul 19 2015, 05:11 PM
QUOTE(gfg3 @ Jul 17 2015, 07:02 AM)
Valvoline VR1 20W50
Geezer914
Jul 19 2015, 06:58 PM
Brad Penn 20/50w summer 15/40w winter (NJ)
Dtjaden
Jul 19 2015, 07:54 PM
Mobil One V-Twin 20-50. Made for air cooled engines. Lots of the good stuff blended in.
Cuda911
Jul 19 2015, 11:20 PM
So, no one else is running canola oil?
phillstek
Jul 20 2015, 03:23 AM
Liqui-Moly MoS2 Leichtlauf 20W-50 in the 3.2 and Swepco 201 in the 915.
Tbrown4x4
Jul 20 2015, 04:34 AM
Another vote for the Brad Penn 20w-50.
Cj Honeycutt
Jul 20 2015, 07:44 AM
My Dad runs this in his Harley air cooled and has for 30K+ trouble free miles. We have both wondered if it would be ideal for the 914's as well. Out of both our engineering camps, so need an oil expert to examine the contents of this oil and add some info.
Cj Honeycutt
Jul 20 2015, 07:49 AM
OOPs. I intended this to go with the Mobil1 20-50 V-Twin air cooled oil posting.
chazt74914
Jul 23 2015, 11:55 AM
I work in the farm diesel industry and was taught that Delo 400 and Rotella T were engineered for over-the-road diesel trucks. Those oils are loaded with sulfated ash to offset the sulfer in diesel fuel.
When used in gas powered tractors, we found a lot of torched valves.
I'm not sure how they perform under high RPM's.
Just an observation.
CHAZT
keely444
Jul 23 2015, 12:43 PM
Brad Penn as well
Mark Henry
Jul 23 2015, 02:16 PM
QUOTE(chazt74914 @ Jul 23 2015, 01:55 PM)
CHAZT
Don't think you have it quite right, sulfated ash was a diesel combustion by-product that could plug exhaust gas particulate filters.
Our engines don't have particulate filters and the oil additive packages have long changed.
steuspeed
Jul 23 2015, 02:42 PM
Valvoline VR1 Racing 20-50 high Zinc formula for older cars. Easy to get at the FLAPS.
I used to run Brad Penn, but read a test where the Valvoline out performed it. Why spend more? And, I can't get it as easy.
Porschef
Jul 23 2015, 04:33 PM
VR-1 20w-50
Not sure if it comes in a 15/40 weight but I'd give that a shot for the cooler months.
Eddie914
Jul 23 2015, 05:44 PM
... the kind that drips on the headers ... hence the "James Bond" smoke screen.
injunmort
Jul 23 2015, 05:52 PM
Valvoline vr 20-50, run it in all air cooled. easy to get at local flaps and never had a problem. run it in my nortons, indian , Harleys and porsches.
