Engman
Feb 26 2005, 09:43 PM
Please see
http://engmanparts.com for details. Set of 2 - will work with up to a 31mm sway bar.
PM or email me.....
M
Jeroen
Feb 27 2005, 07:22 AM
Can you explain a little?
I can see there's more meat to the plate it self, but what about the extra holes?
Engman
Feb 27 2005, 01:58 PM
The 3 holes are to be puddle welded to the car, then weld the edges all around. This plate is almost 50 percent larger than the old ones - you will have to notch out more area to fit it in.
M
Andyrew
Jan 30 2006, 05:24 PM
Whats the ID of the hole?
Engman
Jan 30 2006, 06:42 PM
You can go up to a 31mm sway bar - largest I know of.
M
Andyrew
Jan 31 2006, 03:11 AM
Whats the ID in inches?
I have a 1 1/4in sway bar..
Engman
Jan 31 2006, 12:26 PM
These are sized at 1.24" currently - I *can* open up a set to 1.31" if you are interested.
On a side note - what bar are you planning on running?
M
Andyrew
Jan 31 2006, 02:47 PM
Nascar bar, 1 1/4 in 49 spline turned down to 3/4 inch. should provide between 70-200lbs of stiffness (or more) and i'll make the arms adjustable.
Bar I got from Brett (thanks!!)
Bushing or bearing is my only problem. but I have a couple ideas on that.
Andrew
