QUOTE(Mueller @ Jul 20 2015, 02:41 PM)
Found this while looking for a cheap used MSD or Mallory distributor.....which don't exist for the nice billet distributors
Package dealSlight highjack...the Type IV can use a standard Type I distributor correct?
Yes the T1 and T4 dizzy fitment are the same, main issues are physical size
IIRC the MSD body is too big for a T4 tinwork.
My cheap out on a Mallory is to find a good used redcap dual point Mallory, and use one set of points to fire the MSD.
You can also retrofit a set of pertronix in the old Mallory.
These are 100% exactly the same as a Unilite, except it doesn't have the optical P/U
I've done this many times, MrHyde (Mike Hyde) is running one of the moded old red cap Mallory's with pertronix, per my recommendation, on his 2300cc.
BTW points firing a MSD-AL6 will likely go 50K before they need adjusting and may never wear out. This is because firing the MSD puts very little voltage thru the points.
