background info:
-75 2.0 has 5 lug conversion, recently got my new 16" fuchs refinished and put
205/55 Bridgestone Potenza tires on them. the Rears are 7" and rubbing . the lips had been rolled under (that little edge) but there are 2 factors here- one is the spring and shock set up , and the front of the car is higher than the rear.
my rear shocks are yellow bilistein sport shocks, and springs are weltmeister and seem way too stiff and seem shorter than original.
SO i am wondering if i get new but original spec length springs, and set the circ-clips higher, -now the are on the second frm the bottom- how much higher will the rear sit? Ive heard that the original springs are about an inch longer? That alone could change it enough so that im not rubbing on that one spot? I will end up having to probably massage the inner rear part of the fender to pull it out as well, but it really sits up in there quite a ways as it sits now.
Also this would save me the trouble of trying to lower the front end.
- so any advice from the guys that have these 7" fuchs would help ,, i had read before i got them that others were able to fit them on narrow body cars but not mine- i guess i could have put 195 tires on, or go back to the 16x6" which had plenty of clearance. but now ive already messed up the fender paint- it blistered from the heat of the friction before i got out of the neighborhood . -
at this point i am considering Foley's rear flares. i dont want GT look,
- main point here being springs , spring length and how to get them to stand a bit straighter- will stock longer springs set higher put the rear up much higher to make a diference?
