This has probably been done before, but this was my approach today. Instead of playing with broken gears, etc., I decided to "fix" my VDO clock by eliminating all of the internals and replacing them with a battery-powered quartz movement I bought at Michael's Crafts store for $7.99. I retained the clock face and hands of the VDO so nothing is sacrificed visually. The devil was finding appropriate sized plastic straws to serve as shaft extenders, as the movement is too large to fit inside the can and is attached to the back. This was necessary anyway as it gives you easy access to the battery for changing and the clock setting wheel. The straw shafts ride one inside the other. I used foam rubber inside to give the clock face something to push against and attach to. Naturally, the can and movement had to be installed from the back of the center console fascia, then the rubber grommet, glass, and ring from the front. Installed and seems to be working just fine. First time I have had a working clock since I got the car. Pics below:
Ansbacher
Click to view attachment Click to view attachment Click to view attachment Click to view attachment Click to view attachment
