I have been using the DD CHT gauge for about a year. I'm happy with it - no issues.
QUOTE(falcor75 @ Jul 21 2015, 03:49 AM)
When you fit a CHT gauge do you need to modify the area around the spark plug? Seems like its pretty tight around the plug hole to fit anything there?
Yes, I carefully ground away some of the area around #3 spark plug to get a flush fit with the ring and also to make sure the spark plug sits properly. Also, make sure you order the sender wire that's the right fit for our plugs (14 mm IIRC?). That wasn't an option when I first got my gauge, but it is now, and I've since replace it.
