DRPHIL914
Jul 20 2015, 09:58 PM
What tools are used on doing this? Suggestions, tips and pictures needed,
sb914
Jul 20 2015, 10:07 PM
I've used a baseball bat before. but not on a 914
Mike Bellis
Jul 20 2015, 10:11 PM
I use a modified Eastwood fender roller tool. Modified to fit 5x130mm & 4x130mm
Hank914
Jul 20 2015, 10:15 PM
Baseball bat and a roller.
Search this site, pelican and google. There is a nice video somewhere of a guy doing the bat routine.
Kraftwerk
Jul 20 2015, 11:44 PM
try to borrow the proper tool, & practice on an old junker before doing your car...
& Check YOU tube video's Its where I learned all sorts of things.
DRPHIL914
Jul 21 2015, 10:55 AM
Found a rental site to rent the roller tools and adaptor. Also looking into the Eastwood one.
TravisNeff
Jul 21 2015, 11:51 AM
Please post pics of the procedure, I am in the same boat!
DRPHIL914
Jul 21 2015, 12:20 PM
this thing here....
Mueller
Jul 21 2015, 02:42 PM
QUOTE(Philip W. @ Jul 21 2015, 11:20 AM)
this thing here....
I wouldn't use that....notice it follows a constant radius arc which our 914s do not have.
I've done the baseball bat and 2x4 technique with the help of a friend.
Mike Bellis
Jul 21 2015, 09:12 PM
QUOTE(Mueller @ Jul 21 2015, 01:42 PM)
this thing here....
True on the radius but the tool works great. Needs to be adjusted as you go and you need to keep the paint hot and flexible. Old paint will be too dried out and will crack even with heat. Also depends on the type of paint.
EdwardBlume
Jul 21 2015, 10:37 PM
Baseball bat if you need a little, tools if you need more...
