Geezer914
Jul 21 2015, 11:51 AM
I have a spare wiper motor that does not work. I have checked all the leads and contacts from the plug to the brushes with a test light and have continuity. When I bench test by grounding #31 and the negative ground on the motor cover to the negative battery post and connect post 53 or 53b to the positive post, nothing happens. What do the 2 resistors do? Anyone know where to get replacements?
screenguy914
Jul 21 2015, 12:22 PM
Suggest better help response with either an electrical schematic of the motor and/or a photo. Otherwise, your audience are just owners who know about the specific motor.
If beyond home repair, an electric motor rebuilder should be able to repair it.
Best wishes,
Sherwood
Kraftwerk
Jul 21 2015, 12:46 PM
its GOOD TO StartT WITH A KNOWN WORKING MOTOR IF YOU can. There is probably a good used motor out there somewhere waiting for you.. MY wipers are out too, so I will be watching this thread. IN my experience: anything electric which stops working.. it's the switch that is to blame hardly ever the motor. Though If you think its the resistors they shouldn't be hard to find..
