theleschyouknow
Jul 21 2015, 06:05 PM
hello all seeking a little advice or direction.
I recently had to replace a broken clutch pedal clevis pin and while investigating and diagnosing that I "accidentally" made a clean spot in the 40 years of oil and dirt and grime covering my transmission & my tin & my shocks & my engine & my cvs & well you get the point pretty much everywhere on my underside. After several weeks of maybe getting an hour or so a day in on it I've basically got half the tranny cleaned up- muffler and he's are a bitch to work around!
current state
Click to view attachmentdrivers side & bottom end for reference where it started (pass side of trans was actually worse)
Click to view attachmentI really want to start taking stuff off like the muffler and he's (sure make that valve adjustment a lot easier
)and, God help me, I'm thinking how much easier it'd be if I just dropped the trans, but I'm more than a little freaked out about that. I'm a remove and replace wrench at best and my projects generally end up taking much longer than expected. The stories of broken exhaust studs and helicoils and while I'm in theres weigh heavy on my mind.
It's really too hot to drive it right now but my commute is short and I really want to!
Sorry to have made a short story long but here is the crux of my question(s)
Should I just start (carefully) trying to remove as much shit as possible and see where that leads (is there a gulp! smiley)
or
Should I take it in & pay someone else to clean it up. I'm looking at a local place called Zim's Autoteknik who seem to have a good rep working on classic & late model Porsches and all German autos for that matter
Also thinking about ditching the hand scrub with LAs's Awesome Cleaner and going with some kind of all over spray on engine cleaner with a water rinse off any thing I or whoever should take special care around if that's the route?
appreciate any thoughts or advice especially from those who have gotten in over their heads before. thanks
cjl
Jul 21 2015, 06:40 PM
I would spray with easy off and drive it to the do it yourself car wash but I'm sure there will be 10 posts on why that is a bad idea. Diesel fuel works well too. Again, probably not recommended by people smarter than me.
76-914
Jul 21 2015, 07:17 PM
Clean it yourself and enjoy the journey. You will discover things you previously overlooked or dismissed. It's the first step. Take it.
Elliot Cannon
Pull the car over a big piece of plastic or cardboard and spray the krap out of it with carb cleaner. Don't get any onya.
JawjaPorsche
Jul 21 2015, 07:20 PM
Cans of brake cleaner then hard water spray.
Hank914
Jul 21 2015, 07:58 PM
What they said. Diesel or brake cleaner (but they have to be properly disposed of) or just the Flaps Purple bottle.
Every oil change I spray the purple all over the underside engine and tranny, wait 2 minutes, then I rinse it off with a spray bottle filled with hot water. I do this while jackstanded in my garage. Side benefit: garage floor gets cleaned also, and I then just hose it into the driveway as it is biodegradable.
theleschyouknow
Jul 21 2015, 08:04 PM
thanks for the replies I'm cool with spraying it with x and then a spray hosewater rinse I'm concerned about the hole(s) on the top side of the trans (and other places?) & water getting in there and -73 2.0- I've got a tear in the rubber side shift linkage cover also worried about water in there
those areas I can plug or cover anything else under there that doesn't play well with excessive amounts of water? or cleaner?
paint? rubber? other holes/entry points to the internals?
thanks
cjl
mikedsilva
Jul 21 2015, 08:33 PM
great thread!
I'm new to 914 world but only a couple of months ago, i started doing similar to you.
I would remove the muffler and HE's. Start at the back, and just be methodical in what you do. I use cheap rubber gloves to reduce the gunk getting all over me.
Have a space set aside to put the items so they don't get in the way.
If you have space to use a hose, that is the best and fastest option to remove the most gunk... Perhaps reverse onto some car ramps.. get some decent degreaser/truck wash on the underside and agitate the thick areas with a stiff brush (your dishwashing brush will work well ).
Hose away!
I think you will still have a LOT left on, but for that, you can crawl under and use lots of old rags soaked in diesel fuel, or kerosene.. but I find my local auto parts store sells heavy duty degreaser that works pretty damn well.
Do you know where the oil is coming from?
Kinda looks like it's coming from EVERYWHERE!!
seriously though, it looks perhaps your rear main seal is leaky?
I had NEVER taken a gearbox off before, but I found this job very doable.
There are only 4 bolts holding the gearbox on the engine... the tricky part for me was how to get the nut off the starter!! took me a while to figure that little trick out.. Pretty clever on the part of VW Porsche though...
Cairo94507
Jul 21 2015, 08:50 PM
I would put the car up on ramps and spray it with simple green or some mild biodegradable grease cutter. I would spray it a couple times and let it soak in. I would do that at the end of the driveway, closest to the street and then take a garden hose and rinse all the junk off and down into the sewer so you don't upset your neighbors. I would do that early in the AM to be as covert as possible.
Either that or have someone follow you to the $1 car wash with the pressure wands and put it on ramps there, spray the heck out of it with your degreaser and wash it all off. For that, a weekday early in the AM might be best.
Anything you are concerned about water getting in take some aluminum foil and wrap it tightly or depending on the thing being wrapped, use plastic bags and tape.
Before my car went to Scotty's to be restored, I took it to a truck yard where they do chassis cleaning on RV's and tractors and they put it on their lift and then steamed cleaned the crap out of it. Lots and lots of stuff came off. Easy-peasy but then again I knew it would be getting restored and just wanted to clean as much off it as I could before it got shipped to Scotty. Nobody likes working on a greasy, grimy car.
914Next
Jul 21 2015, 09:22 PM
I'm also taking on the same task. My car is in great shape but still had 47 years of dust, dirt and oil underneath. I've found that the best approach for me is "a little at a time". Tackle one area...might be one wheel well or even just part of the wheel well. View it as a longer term process and you won't frustrated. I started mine 6 months ago and every month or so, I get underneath and clean a bit more. Might be just an hour or two each time. The early stages involve a lot of heavy grease and rags that will see the trash can rather than the washing machine. As you go back each time though and go over an area again, You'll find that you're more and more impressed with the progress and the "dirty" rags actually can be sent through the washer. I still have more to do but what seemed like an impossible task has become a bunch of small cleaning jobs that I rather enjoy.
By the way, I have used mostly simple green or other biodegradable cleaners.
Jeffs9146
Jul 21 2015, 10:50 PM
mgp4591
Jul 21 2015, 10:56 PM
Simple Green and rent a pressure washer with a heater. Spray the cleaner on liberally and let it work, spray it again and wait again... then hit it with the hot high pressure water and don't forget your gloves and goggles. A one piece coverall suit wouldn't be a bad idea either.
theleschyouknow
Jul 22 2015, 09:25 AM
thanks for the responses
I am leaning toward the keep on keeping route one of the reasons I bought my car was to work on & learn on it
jeffs9146 - yep LA's Totally Awesome has all that's been on it so far - spray, let it soak a bit, scrub with stiff nylon brush or green scrubby, wipe with blue shop paper towels
now do it a million times
here's a little tool I made up for nooks & crannies
Click to view attachment mike d - any issues removing he's or muffler? I haven't gotten a good look at the he to engine studs but by the looks of the muffler to he bolts I'm guessing they might have some serious seize to them. I hit them with pb blaster every now and then but have yet to put a wrench on them
cjl
Geezer914
Jul 22 2015, 11:21 AM
It's like pulling off a band aid on your hairy arm. You can do it slow, (lots of pain) or fast, (with a little pain). Take it from experience. Drop the motor & trans, It takes 1/2 hr. to 40 minutes at most. Label all the electrical connections. Get a cheap moving dolly from Harbor Freight. Pelican has instructions and a check list. Then you can remove the engine tin for fresh paint. You will find all kinds of crap under the tin and around the cylinder fins. Get a pressure washer and go to town. I would replace the oil cooler seals and the push rod tube seals. You can adjust the valves and replace the valve cover gaskets. When you are done, it will look like a new motor. While it is out, you can check for any rust like the hell hole under the battery, then clean and paint the engine bay. Good for another 100,000.
rhodyguy
Jul 22 2015, 01:00 PM
do you still have drive-up spray and washes? ramps, rain gear, a couple of cans of brake cleaner and $10 worth of quarters.
mikedsilva
Jul 22 2015, 01:43 PM
QUOTE(theleschyouknow @ Jul 23 2015, 01:25 AM)
cjl
I was careful with mine.. they looked rusty, but they weren't too bad. All I did, was attempt to undo them to see if they were seized or not; turned out that some were a bit loose... and none were seized. I now put some antiseize on the threads to try and make sure they never get seized.
If you have been using PB Blaster, I cannot see any problem if you approach with caution.. only one way to find out!
theleschyouknow
Oct 2 2016, 09:28 AM
still plugging away and got around to cleaning up some suspension pieces
wonder if hans or günter puts these marks on my trailing arms?
Click to view attachment cjl
TheCabinetmaker
Oct 2 2016, 09:43 AM
I always work around the he's. If your header don't leak, leave it on. Too much bad juju when removing headers
theleschyouknow
Oct 2 2016, 10:02 AM
my thoughts exactly
if it ain't broke...
I'll keep plugging away
cjl
veekry9
Oct 2 2016, 10:21 AM
Hazmat suit,full face mask,gloves,breathing mask.*Do not get any of these materials on or in your eyes and skin.
I've found not all brake cleaners are equal,Gunkis the power user's choice.
A few pints of naval jelly for the inevitable rust and natural paint brushes to apply.
A supply of water,laundry detergent or Zep Citrus,bleach and or baking soda to neutralize the acid.
The oven cleaner can mar the alloy surfaces,use lightly in small areas,quickly.It will pull the paint off to metal.
The tar-based sealer used has a modern equivalent in elastomers/polyurethane/epoxy,if originality is not an issue.
A huge effort,on your back,looking up,working in small areas masked off.
The results are worth it tho,a clean bottom,smooth,lighter.
76-914
Oct 2 2016, 10:23 AM
QUOTE(Jeffs9146 @ Jul 21 2015, 09:50 PM)
2nd that.
Just yesterday I was showing Cesar, Ravi and Matt how well it worked. I had managed to "blow" a half a tube of Triple Bond out of the tube and most of that landed on truck. I scraped most of it off with a plastic block after it had dried. However, I was left with quite a mess. I was ready to buff it down with some 3M polishing compound but tried some Awesome first. To my amazement the residue came right off as well as a thin layer of some old single stage. It looked like a new paint job and only took about 10 min's. Impressed the Hell out of me.
914forme
Oct 2 2016, 12:04 PM
The Circle K is a 914 brand from the German Ranch, to make sure you do not russell their 914s. We would round up all the new 914s get our irons white hot, and brand them in the hind quarters where the sun never shined. That is how we find all our long lost 914s. The Sheriff will be stopping by to collect it.
Yes it is a factory mark.
matthepcat
Oct 2 2016, 12:25 PM
Take it to a pro engine steamer. Well worth the money, and then you just need to keep up on maintenance cleaning.
In the Bay Area I go here :http://www.sanjoseautosteamcleaning.com
Lots of air cooled oil leakers always there.
Oct 2 2016, 01:59 PM
we have a high pressure steam cleaner at the shop. Takes 40 years of baked on oil and grime down to bare aluminum.
