Those are original Rivieras (no lip at rim edge), so probably a bit better built than the later repros.
Look on the back side to see if you can find the offset cast numbers, since they were made in both VW & 914 offsets - ET40 being for the 914 & will fit better under the fenders with various tire sizes.
Then post the offset in your ad above.
Good Luck!
Tom
