Harness - brain surgery Big thanks to Kevin today for helping me remove the harness.
Jul 25 2015, 11:40 AM
My mechanic pulled the engine
Jul 25 2015, 11:44 AM
Next step is remove the roll cage and get it up on 4 wheels.
Mueller
Jul 25 2015, 11:48 AM
Nice....now to stop reading your threads....I don't need anymore distractions! hahaha
Jul 25 2015, 11:53 AM
QUOTE(Mueller @ Jul 25 2015, 01:48 PM)
I received the hubs - thanks! Almost too pretty for the "budget build"
Chris H.
Jul 25 2015, 12:13 PM
Nice work pulling the harness complete. Are you doing the wiring conversion yourself? PM me before you start if so. I also have some SVX manuals and other info (might have already sent it to you).
Jul 25 2015, 12:22 PM
QUOTE(Chris H. @ Jul 25 2015, 02:13 PM)
I looked at the smallcar booklet and it was completely overwhelming. So one step at a time. I will remove the tape and plastic and then go from there. Maybe I can trade Wire harness conversion for parts or money.
Chris H.
Jul 25 2015, 06:05 PM
Oh you picked up the smallcar directions? wouldn't mind having a gander at that...
They do harnesses for $700 and only if you don't cut any wires beforehand. Sounds outrageous but it takes a LONG time the first time you do it yourself.
Really though, a lot of the wires for the ECU stay where they are. Relatively few are cut as a percentage. You just change the power circuit, starter circuit, etc.
I found some videos that helped me, including this series:
There are more, so watch all of them that pertain to you and you'll get more confidence. He's doing an Impreza swap, but you want to use the ECU as a standalone as well to control just the engine, not swap out the entire 914 harness for the SVX one.
Also have a lot of supplemental info I can send if you PM me your e-mail address.
914forme
Jul 25 2015, 06:06 PM
Lets get to rocking, Im guessing we could have a race going on for completion. I think you'll most likely be driving before I will. I still have flares to weld on.
BTW, whats with the cage, them welds look like If it is a full SCCA spec cage, I know some one who was looking to pickup a 914 cage. PM me if you want me to get ahold of them.
914forme
Jul 25 2015, 06:09 PM
Wow Chris those videos make me glad I'm doing PEFI, lol I don't have a genius wiring dog.
Chris H.
Jul 25 2015, 06:14 PM
Yeah the first vid is a bit cheesy but it explains the reason he's paring down 80% of the harness, which is what we do. Could have been about 1:30 shorter .
Andyrew
Jul 25 2015, 06:16 PM
Awesome!!
Jul 25 2015, 09:11 PM
QUOTE(914forme @ Jul 25 2015, 08:06 PM)
I don't want the cage but it and some other ugly mods allowed me to get the car cheap enough that once some nice brake and suspension parts were sold, the tub cost $0.00 Since the engine shelf was removed and the trunk bulkhead was hacked out, this car is perfect for a suby conversion. I don't plan to save the cage. It will be cut out and scrapped. I appreciate any and all helpful advise.
Jul 26 2015, 09:11 AM
Since I have these trailing arms I'm guessing I should use the 911 parking brakes.
Jul 26 2015, 09:45 AM
T struts and M calipers. Not pretty but functional from a 911 that upgraded to S calipers. 911 front suspension with elephant bushings came with the car.
Aug 6 2015, 03:19 PM
Using 911 e brake so I bought these from tangerine racing. Seems to be the least hassle solution (just the adapters, using my own trailing arms)
Aug 27 2015, 07:44 PM
So I need a trans. Can anyone help me find the right trans for sale. Not just type but an actual trans for sale so I can just purchase and drive home. I'm around Newark, DE 19711 so anything within about a 2 hour drive would be great. Needs to be a 5mt that will hold up to the 6 cylinder eg33. Thanks!
*I would really like it complete with clutch, flywheel, trans stubs, ect.
76-914
Aug 28 2015, 08:52 AM
QUOTE(mepstein @ Aug 27 2015, 06:44 PM)
Go back and read Chris' or my build thread. Pretty sure all the clutch/tranny info you'll need is there. The TY75 MT5 comes with 4:11's or 3:9's. The 3:9's will give you better hi way gearing.
Cairo94507
Aug 28 2015, 10:09 AM
Mark - How do you keep track of which car you are working on?
Aug 28 2015, 11:41 AM
QUOTE(Cairo94507 @ Aug 28 2015, 12:09 PM)
There's more than one? I told my wife I'm building up the red car.
Aug 28 2015, 11:43 AM
QUOTE(76-914 @ Aug 28 2015, 10:52 AM)
I don't want to find the right trans, I want you guys to find it for me so I can buy it. Really.
Sep 16 2015, 06:32 AM
Zach found me a trans. Picked it up last night. Thank you Vatican Rabbit.
Sep 16 2015, 02:54 PM
A little controversy, or not.
strawman
Sep 17 2015, 11:32 AM
I'm using the transaxle out of a U.S. 1998 Forester into which I've fitted an OBX helical gear limited slip differential. Haven't had it up to highway speeds, so I can't provide opinions. In fact, I haven't yet had it past second gear...
Good luck with your project!
nsyr
Sep 17 2015, 01:57 PM
I have had a fwd subaru trans in my now svx powered 914 for about 9 years. It uses a push type clutch but the stock clutch is strong enough for n/a applications. And it does not need to be converted from awd.
Sep 24 2015, 08:45 PM
more stuff
Jun 25 2016, 07:46 PM
Back on the suby build I sent out the wire harness to get done. It's almost ready. Timothy is making some stock looking gauges that will work with the suby sensors.
76-914
Jun 26 2016, 09:29 AM
I don't know why you'd "farm out" that harness? JK. It's about time you got back on the conversion. Those projects can bury themselves if you let them sit too long. Kent
Jun 26 2016, 01:33 PM
If I didn't farm it out, it wouldn't get done. The 3.2 conversion is almost on the road so I'd like to start working on suby assembly soon.
Oh, I get it. JK.
flmont
Jun 27 2016, 08:31 PM
Whom,..May I asked did u send it out too,..smallcar,..??? Thanks Frank
Jun 27 2016, 09:17 PM
QUOTE(flmont @ Jun 27 2016, 10:31 PM)
A guy on the samba. He's done quite a few and seems very responsive and easy to work with. Asked me questions how I was using the engine, where ecu was going, how I wanted fans to work. Much more than smallcar- fill out the form and send us the money. I think he's also about $150 less than smallcar but that really wasn't how I chose him. There's so much to do on a suby conversion that I wanted as much help and support as I could get.
He mostly worked with the vanagon guys. Here's some of his info - www.facebook.com/jeffrobenolt
www.AutoVenturesLLC.net
Jul 10 2016, 04:30 PM
Here's the harness all done and ready to ship. Jeff labels all the wires and makes it as plug and play as possible. He asked me where and which direction each wire should go and set up the controller for the radiator fans. He told me I'm welcome to call with questions when I get around to putting it all together.
flmont
Jul 11 2016, 05:34 PM
Who did your harness,..?? if I may ask
flmont
Jul 11 2016, 05:35 PM
Sorry,..I just scrolled up,..Jezz.. Thanks
flmont
Jul 11 2016, 06:20 PM
Jan 4 2017, 09:14 PM
I don't want to be known as the guy to where 914 projects go to die. So... Making plans to send this car off to get built by one of the members on this site. He will do engine, trans, mechanicals and get the car running and then I will work on interior and paint. I have to make it a roller and then deliver it around march. At least that's the working plan for now. Details to follow.
76-914
Jan 5 2017, 10:13 AM
That harness looks nice. Who and where is the car going? Build plans???? Any specific's??
Jan 5 2017, 10:33 AM
QUOTE(76-914 @ Jan 5 2017, 11:13 AM)
The plan is to put it together with all the parts already purchased. I'll let the builder talk about his plans when he's ready.
914forme
Jan 5 2017, 05:37 PM
Glad to see this one getting finished up this spring
76-914
Jan 5 2017, 05:46 PM
QUOTE(mepstein @ Jan 5 2017, 08:33 AM)
I should have looked at the title. So let's see; how may have running/completed 3.3 conversions? Chris H. & Bob (aka BIGKAT83), who recently retired, BTW. Who am I forgetting?
flmont
Jan 5 2017, 06:40 PM
Mines not completed yet,..But I do have all major componets required,..just got to assemble everything,..???
Jan 5 2017, 06:57 PM
I still need a radiator and fuel pump but I'll leave the builder to pick the parts he likes. First step is to get it running, then make it pretty with a hardtop and a/c.
914forme
Jan 5 2017, 08:27 PM
QUOTE(76-914 @ Jan 5 2017, 06:46 PM)
914forme
Jan 5 2017, 08:29 PM
QUOTE(mepstein @ Jan 5 2017, 07:57 PM)
That stuff is easy, the hardtop and a/C
76-914
Jan 5 2017, 09:09 PM
QUOTE(914forme @ Jan 5 2017, 06:27 PM)
I didn't know you had gotten yours running. Sorry Stephen.
76-914
Jan 5 2017, 09:11 PM
QUOTE(mepstein @ Jan 5 2017, 04:57 PM)
Ahaa. Scotty
914forme
Jan 5 2017, 10:18 PM
QUOTE(76-914 @ Jan 5 2017, 10:09 PM)
fired in car the old fashioned way, fogging the engine with fuel. So it does not really count just yet.,
76-914
Jan 6 2017, 08:54 AM
QUOTE(914forme @ Jan 5 2017, 08:18 PM)
A wink is as good as a nod.
mgp4591
Jan 6 2017, 02:05 PM
QUOTE(76-914 @ Jan 5 2017, 04:46 PM)
I do the work as I can - I thought it was more important to learn how to walk again... The doc says I'm good for skiing this year though so that's big news. Just gotta get the muscles talked into it.
