QUOTE(rhodyguy @ Jul 26 2015, 01:01 PM)
Have you tried turning the headlight knob to make sure it didn't accidentally get spun to full dim?
yep, i also while replacing the offending fuse, dropped the fuse panel, pulled the switch to check contacts and wire connections. I have a strip of protective rubber between the back of the panel and the body to help prevent any shorting out there.
i have had shorting out before on the back of one of the gauges, and still wonder if that is what i am seeing again. I may pull these gauges and give the going over by Tim to do his LED upgrade. i just think the way Al did it by piggy backing the contacts may be not the best way and i know for a fact that is were i have tripped this fuse before- just never had the headlight thing before- the dash lights are not on the same circuit.
