QUOTE(Mueller @ Jul 26 2015, 03:41 PM)
I'm putting an '89 turbo motor into a my '78 n/a originally equipped car, I just have to keep all the smog related stuff from the '89 and go the local ref station. Last time I checked it was $75 to get the bar code if the ref is happy.
Same here, I have an early 80's Chevy V8 in a '77 Jaguar XJ12. It needs the smog stuff that originally came with the Chevy engine or the car, whichever is newer, then inspection by the referee and you get a CARB sticker for the door. What's cool is the sticker has smog equipment categories so once you have it you can upgrade the stock parts with other CARB legal parts, and the test station sees the sticker and doesn't know what was originally inspected so doesn't object to the new non-factory (performance) replacement parts.
It's true, Dave, they don't let truck engines go into cars, but they do vice-versa as long as you keep the newer smog equipment. That Vanagon-Subaru swap mentioned earlier took Kennedy several years and a lot of back and forth with the Air Resources Board and referees, but all the components they specify now have CARB stickers so the swap's legal. Unfortunately that was done in the 90's so it's only for the Subaru 2.2 engine, no others.
There aren't many exceptions so you're better off sticking with an exempt pre-1976 car. My 914 is a '72 with a 2005 Subaru engine, and in the unlikely case that a CHP ever notices that I'll be selling my car to someone outside California.
