QUOTE(john77 @ Jul 26 2015, 03:11 PM)
Thanks Mark.
Brant, thanks for the info. Let me educate myself a little more first - I'm new to carbs and want to understand what I have and how it relates to the engine in my car before I make any decisions. If I do decide to swap it out you'll be first on the list.
most of the time when these carbs are used on other motor applications, the enrichment tube is removed and plugged.
I had a supertec motor and henry had plugged all 6 of these enrichment circuits
they are usually plugged with a small allen head plug
when intact, there is (as described above( an enrichment circuit that sticks up above the air horn and looks like an upside down "j" or a miniature kitchen faucet
it pulls fuel from the bowl and once primed the vacuum signal from high rpm pulls fuel into the air stream of combustion,
thus the signal has to be strong enough that it only adds extra fuel at high rpm
they do prime and with a wide band AFR you can see that no extra fuel is added the first 2 runs to redline, but once primed they add extra fuel
probably a better idea for street than race, but my car is set up and has always ran them, so thus my interest
due to this extra fuel, the jetting for the rest of the carb has to be adjusted to compensate
but it does allow you to run a more lean mid range and still have adequate fuel for very high rpm
with the circuit plugged (most likely in your case) its just a standard carb in application.
note you can not run the enrichment tubes with tall aux 2ndary venturi's
and also note that there are different jets available for the enrichment tubes, so that the amount of fuel added could be metered or adjusted.
once the tubes are removed, they are very hard to find used
took me a year to fine the set I have now.
although supertec must have a box of them somewhere....
