Ok so I just went thru the front suspension. New rubber bushings, ball joints, tie rods. When I put it all back the ride height was very low and I used all of the adjustment on the adjusters.
I know you can remove the rear cap and change the position on the spline but considering how low it is there is not enough adjustment to raise it to the right height.
Is there some trick to hold the bar in place while changing the position of the rear cap? It seems if I remove the cap any tension in the bar will be lost and it must have more tension to raise the height.
I must be missing something.
