7TPorsh
Jul 28 2015, 04:49 PM
Working out installing a msds T4 header and am considering muffler options. My first choice was to attach a flowmaster to the end of the collector and add a tail pipe....header exits on the driver's side.
It is turning out there may not be enough room since the header collector and reducer put the flange out near the end of the trans. I can route the pipe and muffler across the back and exit the passenger's side but then I need to change my valance.
I think curving the pipe back to the driver's side will be tight; and hard to find a shop to spend the time.
I remember seeing some kind of 911 muffler, banana type, that had the inlet and exit on the same side. Was that a custom job? Are they effective?
Has anyone done this setup? How do you mount the muffler?
914forme
Jul 28 2015, 05:10 PM
QUOTE(7TPorsh @ Jul 28 2015, 06:49 PM)
Tangerine Racing - EVO II silencer. Single inlet, and outlet, streatable muffler, anything Chris does and sells seems to work very well. Im sure if you ask he can work something up, though his header is the best one I ever owned.
era vulgaris
Jul 28 2015, 05:26 PM
QUOTE(914forme @ Jul 28 2015, 07:10 PM)
I'm running the Evo II as well as the tangerine 1 5/8 racing header. Very happy with it! Really deep and throaty at idle, up to a scream at high rpms. I almost shat myself the first time I heard it fire it sounded so good!
I'll also say that the stub pipes on the header are a bit of genius. No need to remove the exhaust studs if you need to pull the header.
http://www.tangerineracing.com/914headers.htm
7TPorsh
Jul 28 2015, 07:27 PM
Tangerine is way out of my budget. Was thinking an sc muffler. ?
7TPorsh
Jul 29 2015, 11:24 AM
I am thinking of one of these? Anyone have one on a 914?
porschetub
Jul 29 2015, 04:37 PM
I don't see why not they are a pretty good design,without seeing your system you could have some clearance issues so some work may be required there.
Upside....easier to find than the dual inlet (cheaper),should give a nice exhaust note also
Downsides.....they are very heavy and will need good support,perhaps the stock support bracket may need beefing up and modified more like the bracket on the 911 then you could use those 911 clamps.
Renspeed (i think) have the clamps in stainless....very good quality bought a set last month.
aircooledtechguy
Jul 29 2015, 05:29 PM
I'm about a month away from firing mine up for the Squarsche. I'll let you know how it sounds and works.
Chris914n6
Jul 30 2015, 01:38 AM
I have the SC on my nissan vq30. Exits out the factory valance notch on the drivers side. Fit is good.
It's a 75 chassis so I welded on brackets to hang it from bolts where the bumper shocks used to be.
7TPorsh
Jul 30 2015, 10:17 AM
Here is what I am looking at...car is on ramps so pics are a little difficult. You can see how far out the header comes. I can't seem to slide the collector all the way on. When I add the reducer there's no room for a muffler.
There is a lot of room back there and thought this sc muffler setup may work but i don't know dimensions of the muffler...will it fit up behind the bumper and valance?
Can I mount it to the stock bracket points and run the pipes in and out?
Click to view attachmentClick to view attachment
Chris914n6
Jul 30 2015, 05:59 PM
Dave_Darling
Jul 31 2015, 09:00 AM
Is that a rubber mount between the muffler and body?
--DD
Chris914n6
Jul 31 2015, 01:23 PM
^^ Yes. Technically a repurposed section from a tire with holes punched in it. Never seem them before but evidently common, as a former Midas Muffler shop mechanic did it back in my RH days. He overruled my plan to use straps over the shield a'la 911.
First pic I found.
7TPorsh
Jul 31 2015, 02:34 PM
So it is not hard connected? is all the weight on the exhaust studs?.
i am thinking the entire exhaust system needs to be hard connected and supported.
Dave_Darling
Jul 31 2015, 03:26 PM
If it gets hard connected, it must be to the transaxle, not the body! (Which includes the heat shield.) The whole drivetrain moves around, and if you solid mount the muffler to the body it will break the muffler, or the exhaust, or the exhaust studs. Something's gotta give, as they say.
The soft mount should support the weight of the muffler, but still allow it to move as the drivetrain moves. Hopefully it's good enough.
--DD
Chris914n6
Jul 31 2015, 05:47 PM
No weight on the studs, it's all supported by the rubber straps. Since the pre-75 doesn't have the body nuts for the bumper shocks, it would be easier to make a support bracket following the factory design. As you would say... hard connected.
Given how rusty my muffler turned out being this was the better choice, and with consideration of future plans.
7TPorsh
Jul 31 2015, 07:23 PM
I'm thinking to weld on a factory bracket and bolt up to the end of the trans. Then run the pipes in and out.
porschetub
Aug 1 2015, 11:38 PM
QUOTE(7TPorsh @ Aug 1 2015, 01:23 PM)
Yep mentioned that ,find a 911 exhaust mount and mod that and mix and match with the 914 one...,cheers.
7TPorsh
Aug 4 2015, 04:03 PM
Well I have decided to go a different route. I am thinking any affordable muffler is going to probably be shot. a good one is $250+.
So going with this Magnaflow turbo muffler. It will be mounted behind the trans.
don-6
Aug 4 2015, 06:12 PM
I have an 86 Carrera Muffler. PM sent.
7TPorsh
Aug 7 2015, 11:28 AM
WHat do you guys do with the clutch and speedo cable? Mine is routed on top of the engine bar but it's rubbing the header now..Also I'm cooking the left side e-brake cable.
Do I need to re-do the clutch pulley somehow?
7TPorsh
Aug 7 2015, 11:32 AM
QUOTE(7TPorsh @ Aug 7 2015, 10:28 AM)
ThePaintedMan
Aug 7 2015, 12:19 PM
Look up "Clutch Pulley Adapter" on Chris' website. You absolutely need to re-route it or it won't last more than a minute with the heat from the header.
http://tangerineracing.com/transmission.htmAlso, I would HIGHLY recommend some kind of heat wrap for the cable. Chris sells those further down on that page.
rhodyguy
Aug 7 2015, 12:27 PM
Also note Chris sells insulating sleeve material for cables.
914work
Aug 7 2015, 01:06 PM
QUOTE(aircooledtechguy @ Jul 29 2015, 04:29 PM)
Nate did you enlarge that inlet/flange?
7TPorsh
Aug 14 2015, 12:36 PM
Lots of things to deal with when adding a header:
- the clutch and speedo cable
- the driver side e brake cable
....and now pipe diameter. The header collects into a 2.5" pipe. The muffler i am going to use also has 2.5" inlet and outlet. Am I ok running 2.5" the entire length or should i be reducing it to 2.25 or 2" .
I can reduce before and after the muffler...or just after. I noticed the 911 exhaust tips are for 2.5"
Running a tweaked 1.7 with dual carbs and a cam. Is 2.5" too big?
7TPorsh
Sep 14 2015, 01:47 PM
Welding day at the local muffler shop...the before shot
Click to view attachmentWHat's going in???
7TPorsh
Sep 14 2015, 01:51 PM
7TPorsh
Sep 14 2015, 01:53 PM
Nice Clean butt! ... and sounds really good!
Chris H.
Sep 14 2015, 02:15 PM
Looks great!
Dave_Darling
Sep 14 2015, 04:43 PM
If it's feasible, I would suggest supporting the muffler off the end of the transmission, the way the factory did it. The whole drivetrain can move relative to the body. If you've got a hard mount from the muffler to the body, that can put stress on the headers or the various joints in the system. If the system can handle that, it's cool. But if the joints are solid, that's not so good.
If you mount to the transmission, the mounting should keep its position relative to the exhaust ports pretty well. Much less flexing is needed that way.
--DD
7TPorsh
Sep 15 2015, 09:24 AM
QUOTE(Dave_Darling @ Sep 14 2015, 03:43 PM)
--DD
Thanks Dave, you are exactly correct. We cut some of the stock mount arm off and welded the bracket to the back of the muffler on one side and the pipe on the other. So yes supported entirely by the drive-train; no body mounts at all.
7TPorsh
Sep 15 2015, 09:27 AM
Also notice the Tangerine Racing piece to lower the clutch cable....kinda neat how it's tangerine color...
Maltese Falcon
Sep 15 2015, 07:44 PM
Excellent fabrication, he is a first class muffler guy
Post a sound track with the Magnaflow muffler when you get a chance !
Marty
7TPorsh
Jun 16 2017, 08:57 AM
Here's an update (sound of typewriters)....what's a typewriter?
Since the car is getting some treats I decided to update my sound. The Magnaflow I have been running is quieter than stock....
Everyone brags about the sound, etc, etc. Yeah it looks shiny but no sound.
So following some advice from Marty (Maltese Falcon) I looked into SpinTech. Called them up Monday and custom ordered my configuration.
2.5" single inlet / 2.25" split dual outlet.
In my hand Thursday afternoon....incredible. off to the muffler shop once the car gets it's new shifter bushings...
Click to view attachmentClick to view attachmentCar will have a 911 exhaust tip on each side....need a new right side valance cutout now.
Mark Henry
Jun 16 2017, 10:06 AM
QUOTE(7TPorsh @ Aug 7 2015, 01:28 PM)
Fire sleeve and hose hangers.
Tangerine had a pulley bracket that flips the bracket on it's side.
Mark Henry
Jun 16 2017, 04:01 PM
Just did my e-brake cable with fire sleeve.
I should have used a smaller diameter, maybe 1/2", but I had 1" on hand. I'll try to tie it up so it's not touching later.
It's a /6 but you get the idea.
Maltese Falcon
Jun 16 2017, 10:06 PM
Can't wait to see the finished product Gary...see you at the Petersen Cruise-in Sunday 6/25/17 ? We will be there in something grey with carbon ceramic brakes/ big yellow Brembos
7TPorsh
Jul 26 2017, 09:55 AM
ing my thread to post an update.
After playing around with the looks of the car and making it a little more racy, I'm came to the realization that the car was too quiet. Sounds great but too quiet.
I totally recommend the Magnaflow to anyone looking for a deep tone sound without much of an increase in volume from stock. ...and i'm running a header too.
So I did some research, measurements, etc. and decided on a SpinTech "Camaro" type muffler. These have a single inlet and dual outlets. Spintech builds these to your specs if not already available. They did a 2 1/2" inlet and dual 2 1/4" outlets for me and I had it in 4 days from SoCal.
Looks low but really isn't; just cause of the color... still higher than engine/tranny...
Different welder.....this guy is in Chatsworth and is awesome....former Porsche mechanic from TRE. Look at the quality of the welds/bends....very satisfied.
New sound? Unbelievable!! Louder-Yes Deeper-Yes Racy-Yes Yes Yes
car has a Ferrari ish growl between shifts that I'm really liking, I know why they call it "Spin" Tech now. It's like a really deep
BRRRRrrrrrrr[size=5] as the revs go down.....
Click to view attachmentClick to view attachmentClick to view attachmentClick to view attachmentClick to view attachment
Mueller
Jan 3 2018, 10:54 AM
^Still enjoying that SpinTech muffler setup?
7TPorsh
Jan 3 2018, 12:40 PM
Oh yeah, I get nothing but compliments....everyone thinks it's a 6 . Really deep sound...
Larmo63
Jan 3 2018, 11:09 PM
Tangerine clutch pulley set-up with Patrick Motorsports delrin pulley:
