I have some 96mm p&C from AA. The pistons are flat top with a cut out for high valve lift.
These pistons have no arrows on the tops (point to flywheel) although the ones in the picture do
My question is this; When installing the piston the cutouts should be on the lower part of the cylinders the same side as the pushrods? If you understand what I mean. I guess this is a dumb question but I dont want to mess it up
Thanks
