VWTortuga336
Aug 1 2015, 12:52 PM
I'm sure this has been covered, but I couldn't seem to find exactly what I was looking for:
My 74' currently has a set of OLD 165 SR 15 tires that need to be replaced. I believe on the height they say "85S" but it's hard to tell since they are so old... I'm looking for something a little more low profile, since these just don't seem to sit quite right with the low stance of the car.
Does anyone have any suggestions?
Mark Henry
Aug 1 2015, 01:20 PM
I find lower profile tires just look odd.
195/65-15 is one of the best fits on a narrow body, but on the odd car they rub the rear fender.
JeffBowlsby
Aug 1 2015, 02:15 PM
See Michelin, Vredestien
thelogo
Aug 1 2015, 10:07 PM
QUOTE(Mark Henry @ Aug 1 2015, 12:20 PM)
I 2nd that
, 196-65-15 touring tires
But the rears fit tight
VWTortuga336
Aug 1 2015, 10:12 PM
Thanks for the input guys, I think that's what I'll look for. Anyone have any pics of this setup?
No issues on my Mahle's going from 165 to 195?
Dave_Darling
Aug 1 2015, 10:34 PM
No issues WRT the wheels. But as has been said, they may rub on one rear fender or the other. A little judicious pulling should be able to fix that, or possibly mashing the fender lip flat.
--DD
Mark Henry
Aug 2 2015, 12:48 PM
I doubt if they still making them, but my car came with a set of 185/70-15 that fit perfectly.
dlkawashima
Aug 2 2015, 11:52 PM
Pirelli makes the Classic line of tires and has the CN36 in 185/70HR15 and the CA67 in 165HR15 sizes.
Prices are ... well, they're not cheap but they are period correct (especially the CA67 if you have a 2-liter) if you're going for originality.
CN36 on left, CA 67 on right
maf914
Aug 4 2015, 06:21 AM
Tire Rack Pirelli P6000 185/70 x 15. Not real cheap though.
http://www.tirerack.com/tires/TireSearchRe...7&zip-code=
johannes
Aug 4 2015, 08:10 AM
I install 185x65x15. They are a bit smaller than original but they are cheap and you can find a lot of brands in this size. Never had issues with rubing even with non standard offset rims
VWTortuga336
Aug 4 2015, 11:03 AM
Could anyone post a pic of their car with 185 65 15's installed? I'd like to see how they look on the car before purchasing.
dlkawashima
Aug 4 2015, 11:30 AM
QUOTE(VWTortuga336 @ Aug 4 2015, 10:03 AM)
Personally, I'd be less concerned about the look and more concerned about the speedo error and higher RPMs on the freeway.
siverson
Aug 4 2015, 04:52 PM
Great tire size IMO.
http://www.914world.com/bbs2/index.php?s=&...t&p=2111511-Steve
johannes
Aug 5 2015, 12:24 AM
You must be aware that speedo is 5% off with the 185/65/15 tires. You have 5% more rpm at cruising speed, but as the 914 has very long gearing, I found this is not a problem. When cruising at 80mph its only a 200rpm difference.
As I said before this tire size is very popular (in Europe at least) and there is a very large offer. Therefore prices are lower than on other sizes
Before I had 185/70/15, that is the corrct outer diameter but got inner rub when I turned lock to lock
Here is a picture from pelican parts forum with 185/65/15 tires on a 914
maf914
Aug 5 2015, 06:53 AM
I used 185/70 x 15 tires, first Uniroyals then Pirellis, on my car for many years and was satisfied with the performance. The diameter is very close to the original 165 x 15 OEM tires that came on the car, so the speedo was also close.
