SteveL
Feb 28 2005, 09:26 AM
The UPS truck just left after dropping off my new-to-me muffler for my 1.8.
Rusty described it as excellent condition, and it is at least that, if not better. It still has some of the factory primer on it even, and absolutely no rust - not even surface rust. I want to coat it to keep it that way. I've tried hi-temp bar-b-queue paint before, with less than stellar results. What have others used that works well?
TIA
Steve
scotty914
Feb 28 2005, 09:28 AM
por 15 manifold paint
Cap'n Krusty
Feb 28 2005, 10:03 AM
Cold Galvanizing paint, available at welding supply stores. Even the "correct" color. The Cap'n
Rusty
Feb 28 2005, 10:13 AM
Glad it worked for ya!
-Rusty
Eric_Shea
Feb 28 2005, 10:21 AM
QUOTE |
por 15 manifold paint |
Which is called POR-20. I did both systems with it. New 914 headers got blasted and then repainted with POR-20. Sport muffler as well. 911 heat exchangers and stock muffler got the treatment as well.
Should be good to 1400 deg.
Others here (Jim) said it still looks as good as the day it was applied.
StratPlayer
Feb 28 2005, 11:22 AM
Go with Por20 or Bill Hirsh high temp paint good for 2K degrees.
http://www.hirschauto.com/acb/showdetl.cfm...ct_ID=11&DID=27
Type 4
Feb 28 2005, 11:26 AM
Bill Hirsh 1800 Hi temp get the pint can rather than the spray can.
It works really well.
bperry
Feb 28 2005, 12:01 PM
So are you guys spraying it on or using brushes?
--- bill
StratPlayer
Feb 28 2005, 12:27 PM
I just refurbished a set of 75-76 exchangers, I used Bill Hirsh high temp paint on the exhangers and plumming, I used the spray can paint that he sells. On my car I painted the muffler with por20 high temp paint and I brushed this paint on the muffler. It shows no brush marks when this paint drys.
Eric_Shea
Feb 28 2005, 01:38 PM
For mine (POR20) we sprayed... headers heat exchangers, all a big spaghetti mess. For a muffler I'd just brush it on.
Type 4
Feb 28 2005, 03:56 PM
I use a foam Brush.
SteveL
Mar 1 2005, 10:52 AM
I picked up some of the POR 20 - the only color they had is "Brilliant Aluminum". Is that the only color it comes in? I did a test piece and it's pretty bright silver. I think it would looke kinda ricey. Are other colors available? What about the POR Manifold paint - the can says it replicated the gray color of factory cast parts.
Triaddave
Mar 1 2005, 10:59 AM
VHT make a high temp paint in a spray can.(VHT, very high temp 1500 degree) seen in excellence or performance catologs, allow at least two cans. the local auto stores only usually stock the 1200 stuff,junk
