StratPlayer
Aug 3 2015, 10:19 AM
Will a wheel spacer prevent a tire from rubbing on the fender well?
TheCabinetmaker
Aug 3 2015, 10:53 AM
The tire is rubbing on the inside?
Elliot Cannon
Aug 3 2015, 10:59 AM
QUOTE(StratPlayer @ Aug 3 2015, 09:19 AM)
Adding a wheel spacer will help if the tire is rubbing on the inside of the fender. If the tire is rubbing on the outside of the fender, you need a wider fender or a narrower tire.
JRust
Aug 3 2015, 11:40 AM
QUOTE(Elliot Cannon @ Aug 3 2015, 09:59 AM)
Elliot is right for once
shoguneagle
Aug 3 2015, 12:02 PM
Glad to see Elliot right for once; that means - - - - JRust is definitely wrong on this one. Fact: JRust is always wrong which means Elliot is always right!!
Love to "pick on Mr. Rust". Don't you???
LOL
Larmo63
Aug 3 2015, 12:27 PM
Just be sure your lugs or lug nuts are long enough and safe to run spacers
johnhora
Aug 3 2015, 02:35 PM
QUOTE(Larmo63 @ Aug 3 2015, 10:27 AM)
Absolute Must!
porschetub
Aug 3 2015, 06:50 PM
Example : studs are 14mm thread you must have 14mm of thread protruding to hold the nut,however.....for alloy nuts a like a little more.
You would most likely get away with a shim spacer (6-8mm) unless you have really fat tyres,from memory anything up to 10mm will be ok without the need for longer studs,cheers.
jcd914
Aug 3 2015, 08:03 PM
The rule of thumb I was taught:
For steel nuts & studs you want a nut to stud engagement equal to the diameter of the stud. So for a 14mm diameter stud you want a nut the threads on 14mm or almost 10 turns of the nut (1.5mm thread pitch).
For Aluminum nuts on steel studs you want a nut to stud engagement equal to 1.5 times the diameter of the stud. So for a 14mm diameter stud you want a nut the threads on 21mm or 14 full turns of the nut.
Jim
