I am installing a volt meter using a relay. I am running a dedicated wire from the battery to the volt meter. The relay gets wired as follows:
30 Battery in
87 To volt meter
86 To ground
85 To fuse panel
Which fuse number on the fuse panel should I connect to 85 on the relay
