Thanks Rob and Stephen on the lines and bracket. An unplanned set back for sure, with the design and fabrication of the par,t but well worth it, and it even resulted in a few other benefits. One of which is that with the new mounting I have a better way to secure the trunk board and I was able to install a much improved fuel tank drain shut off.
Saturday added oil, 11 quarts to begin with, Removed the spark plugs to allow the engine to rotate more freely for first cranking to verify oil pressure and circulate the oil. Sorted through some more electrical issues with a lot of trouble shooting.
Sunday finished trouble shooting and then fabricated a new battery cable and fit. I even incorporated the battery terminal from 914 Rubber to top it off. Much better set up!
The car is still on jack stands at the suggestion of my buddy toolguy in the event of any oil leaks. Good idea!
FIRST CRANK, still with still no plugs yielded 25 psi oil pressure! No oil leaks!
The thing isn't even running yet, but you have no idea what it was like to see and hear the engine cranking on starter, see the oil pressure building on my quad guage and look through the engine cabin access panel to see the engine turning. Big deal, in that as I have said many times, electrical is not my strong suit. Have learned an awful lot with this project and am more comfortable now. Not to mention building the engine myself.
After helping a neighbor all morning with his patio cover roof, I worked most of the day even missing, unfortunately, the majority of the Datona 500.
But it was worth it with the progress I made. Between the new battery cable and half the engine compartment fuel lines complete I am much closer. As I mentioned earlier I am incorporating "pre filters" from the regulator to the carbs as a safeguard further complicating my set up.
Have an opportunity to spend time with granddaughters today so that trumps things here and I just may take the time to install the Mark Henry Ford starter solenoid before coming off the jack stands. So we'll see. Almost there!
