Below are the key points from the thread I posted that I wanted captured here in my build thread.
"Anybody Have This 22mm Weltmeister Front Sway Bar?, Don't understand what keeps it centered"
I thank you one and all for all the help. This is truly a great thread!
___________________________________________
pete000 Apr 20 2018, 09:28 PM Post #2I have that same bar but haven't had any issues with it drifting.
Steve Apr 20 2018, 09:33 PM Post #3I used to have that Weltmeister bar. The bushing should look the same on both
sides with about an 1/8” sticking out on both sides. You center the bar with the
arms flush to the bushing on both sides. They do have a tendency to move side
to side. Either dump the whole thing and buy a tarret bar or buy some clamps
on the inside from McMaster Carr.
defianty Apr 20 2018, 11:48 PM Post #6 I have the same bar Jim. Although I've never run with it yet I did purchase
two shaft collars with grubs to alleviate any lateral movement. Plan is to install
them on the inner wheel well next to the sway bar support plates. I also got some
large nylon washers to stop any contact.
I'm sure I got this idea from someone on here so hopefully they'll be along soon.
with pictures.
One problem I did have was finding a 19mm collar. In the end I got 18mm
and had a friend machine them out to size.
_____________________________________________
Luke M Apr 21 2018, 06:59 AM Post #7 I have a brand new welt bar that I haven't installed yet. I do see the kit comes
with 2 hose clamps which would clamp around the bar under the fuel tank. I
would say this is to keep the bar from drifting left to right. I plan on replacing
the clamps for collars when I do install it.
____________________________________________________
jcd914 Apr 21 2018, 10:20 AM Post #9I have dealt with this in a few ways.
First push the bushing all the way in to the bush cup mounted to the inner fender, they should only stick a short distance.
Then loosen the arms on the bar and work them in as far as they will go.
The arms clamp on the square end of the bar and can move around if loose or
may not have been install pushed on to the bar as far as possible.
Now you will know how much gap you have to deal with.
I have had some where there was very little gap and the bar could only move
back and forth a few mm.
If you have enough gap your bar will move side to side much, there are different
ways to fill the gap.
However you deal with the gap you want to end up with the arms equally spaced
on each side of the car in order to keep the geometry of the swaybar arms, drop
links and A-arms the same.
The hose clamp the some kits come with is functional but I don't like it.
Clamp on collars work much better but you then might have metal rubbing
against metal depending on where you install them.
I have always put them on the outside, between the swaybar arm and the bushing.
It means you don't have to remove the fuel tank if you want to take the bar out
or if a collar worked loose and needs to be tightened.
I have had spacers made of plastic bushing material (turcite), basically a pair of
large plastic washers that fit over the bar and go between the arm and the
bushing end or the bushing cup.
I have had wider bushing made up that have a step so the push into the bushing
cup and stop against the outer edge and have a larger surface for the swaybar
arm to rub against.
I have also (in a pinch) taken a PVC pipe fitting that fit over the bar and cut it
into spacers to fit between the sway bar arm and the bushing to fill the gap.
Note: I did not do this on a customers car, not a real professional solution but it
worked.
You just want the bar centered and set up with very little play to move side to
side.
Jim
wysri9 @ Apr 23 2018, 02:30 PM) I took a good look at mine and although this is only a test build, things seem to snug up nicely. I could detect no play between the bushings. here are some pics:-
Lucky9146 Apr 25 2018, 10:10 PM
Looks great and thanks for the pics. Your picture shows very well the large space from the arm to the cotter pin.
Click to view attachmentI have my issue figured out. When the car came to me I thought it was set up as I had been told the car had seen 145 mph clocked at a track with a big 4. I should have checked it and did not.
It appears that the arms either were not tight or had walked outboard toward the cotter pin. I plan to put some type of spacer between the arm and the cotter pin just to ensure it does stay in place. Thanks again
jcd914 Apr 25 2018, 04:30 PM Post #16QUOTE(Lucky9146 @ Apr 25 2018, 09:53 AM)
Finally came to the realization that the drop links on mine are incorrect and way
too short.
This can be seen from the picture sent by wysri9 here. At the time this photo was
posted I was more concerned with the slider arm and all the extra space to the
cotter pin to digest this now obvious fact. It wasn't until I tried to reassemble that
things just did not make sense.
Click to view attachmentSpoke with Jason at Paragon Products in Corpus Christie TX and he confirmed it.
The drop link should be 6 7/8" long and mine is only 4 7/8' long.
Explains a lot. The front suspension was so pre-loaded and the A arms actually
hung on the sway bar arms as opposed to the struts. Now I understand why it was
so hard to get it apart. A full 2" too short?
Keep in mind I barely have this thing on the road, still sorting out the bugs and
break the engine in, so very few miles yet to guage anything.
The correct length for your drop link is dependent on the ride height of your car.
Ideally the sway bar arm should be parallel to the ground when the car is settled
on its suspension. So the length of the drop link would be different depending on
your ride height. I have shortened many sets of drop links to match them to the
car they are going on.
I think the Weltmeister drop links are too long to begin with except for car
sitting at full height.
I would wait to change the drop links until you can get the car on the ground and
settled and see where the arm is._______________________________________________
Lucky9146 Apr 26 2018, 10:10 PMjcd914 is correct that the drop link is dependent on the ride height. My car is low.
I set the car on the suspension with the sway bar arms horizontal to the ground and the 4 7/8" drop links that I had fit perfectly!
Personally, I think the Weltmeister instructions suck.
Thank you jcd914 This is a great site!
