So I'm getting ready to reattach the transmission to the engine and I had a few questions: 1. What parts do i lubricate? 2. What kind of lubricant do I use? 3. How much do I use?
Let me know if it would be helpful to post any pictures. Thanks!
Dave_Darling
Aug 5 2015, 09:57 PM
A little grease (Moly works fine) on the pivot for the clutch arm. None on the throwout bearing; it is internally lubricated. Some grease in the pilot bearing inside the flywheel. That's all I can think of.
--DD
914 RZ-1
Aug 6 2015, 06:37 PM
QUOTE(Dave_Darling @ Aug 5 2015, 08:57 PM)
--DD
Thanks! Do I need any lube on the pivot points of the throwout bearing (the 2 axles at the end of the wishbone)?
Mike Bellis
Aug 6 2015, 06:47 PM
A tiny bit can't hurt but you don't want it getting on your clutch disc.
