A little more Porsche trivia.
The first picture is a 356 transmission intermediate plate from about 1962. The bearings are held a retainer that completely covers the bearings. The original version of the retaining plate from 1958 was similar to the 901/914 plate in that the mainshaft bearing was held by a fork that did not enclose the bearing. Porsche saw a need to strengthen the bearing support for the late 356 transmissions but forgot this lesson when they designed the 901.
The 901 1965-69 transmission was aluminum and didn't have problems with loose intermediate plate bearings. 1st gear syncho would wear out and the mainshaft ball bearing would sometimes fail at less than 100,000KM.
In the middle of the 1969 model year, Porsche introduced the mag case transmission in the 911 parallel to the 914. Most of the bearings and gears from the earlier aluminum case were reused in the later type.
Two pictures show typical wear on a 914 intermediate plate. If you can feel a ridge with your finger nail in the bearing bore or the bearing flange seat, it is not reusable.
The next pictures show typical wear on a retaining plate and a reworked plate.
Click to view attachment Click to view attachmentClick to view attachmentClick to view attachment[attachmentid=511
449]
