Lawrence
Jun 8 2003, 05:45 PM
I'm gonna clean the muffler and scrape/beadblast the rust off.
What is good to use as a muffler paint, that will last more than the first 10 minutes of hot exhaust? BBQ grill paint?
Aaron Cox
Jun 8 2003, 05:46 PM
try high temp engine paint...(this is what i used on my engine tin) or BBQ paint
Jeroen
Jun 8 2003, 05:57 PM
POR15 also has a high-temp coating
No real world experiences though...
cheers,
Jeroen
I think we used POR15 (I assume high temp) on the Bee and it didn't work out well...I don't recall the details for sure other than a lot of time spent painting and a short amount of time watching it burn off.
I know Holt sells something called Very High Temperature Paint used in the airplane industry....
-Pam
ChrisReale
Jun 8 2003, 06:11 PM
Por 15 only works if you follow the directions to the last period. You need to marine clean it, metal ready it and then paint it.
Id try to get it coated instead of painted, like Kevin Powers did with his Triad exhaust.
Lawrence
Jun 8 2003, 06:14 PM
You're right, Pam. We did.
But it wasn't the high-temp flavor, and I thought it was. My fault.
-Rusty
Andyrew
Jun 8 2003, 06:17 PM
High temp paint is what I would use, A trip to FLAPS to get caliper paint and I saw some very high temp.. 1150 f, I think was the highest I saw. Good luck!
Check out the Holt stuff - I know they had a website when I had to buy it for the pilots at work...maybe it will be less expensive than POR15 high temp
Re: using the wrong POR15 - I'm sure by the time we were going to apply it - I'd lost the instructions in that SAME place I lost several "impossible to replace" bolts
-Pam
MarkV
Jun 8 2003, 06:21 PM
I painted my used banana
muffler. Sanded it down to bare metal & primed it w/ zinc spray can primer. I painted over the primer w/ gray VHT brand spray can high heat paint. It’s been almost a year & it hasn't burned off.
StratPlayer
Jun 8 2003, 06:30 PM
I just finished painting my muffler using Por 20 not por 15,, I used the Por 20 Black Satin its a high temp paint and it came out very well.
J P Stein
Jun 8 2003, 06:39 PM
I use srove paint on my headers. 1200 deg stuff.
Wurks fine & is cheep & black. Recoat every couple years.
TMorr
Jun 8 2003, 07:20 PM
I recently restored an Abarth muffler for my 911, after glass bead, I used this Eastwood product.
http://www.eastwoodco.com/aspfiles/itemdy0...+Z&Dep_Key1=spcIf the link is not good, check for product 10183, thats the Eastwood #
Very thin, used a couple or three coats, but the result is good so far, good flat / satin finish.
One can would do at least four 911 mufflers.
Regards
Hayden
PTBT
914Timo
Jun 9 2003, 12:41 AM
I just painted my banana mufler with VHT satin black
engine paint. The headers I painted VHT silver
1200 deg stuff. After first test drive they still look good.....
Lawrence
Jun 9 2003, 07:11 AM
Hey.. thanks for all the info. Sounds like I can make it all squeaky clean and nice again!
-Rusty
Kargeek
Jun 11 2003, 12:14 AM
A nice factory look is to use Wurth zinc spray or their aluma-zinc spray. I've used both and they work great and can be touched up later. DH
Dad Roberts
Jun 11 2003, 05:35 PM
Rusty.......the Eastwood exhaust stuff works great. I have used it for years on exhaust manifolds, and tubing. On the mainfolds it looks like an original casting.....on tubing, you will have to work a lil harder to get a nice look. Once you apply the stuff, you must run the motor and bake it in. Fumes are VERY bad, need LOTSA ventilation. Good Luck.....
........Dad.....
Lawrence
Jun 11 2003, 05:51 PM
Thanks, Dad. That certainly is an option that I need to look at.
Anyone ever use high-temp powdercoating? I've seen some advertised that claim to stand up to 1000 degree temps.
-Rusty
seanery
Jun 11 2003, 05:55 PM
what about sending it out? I think Jet-Hott will do mufflers.
Lawrence
Jun 11 2003, 06:28 PM
Sure they will. But I'd love to be able to do it myself... after all, I'll have all the equipment.
I'm gonna be a powder coating fool.
