QUOTE(oildrips @ Aug 7 2015, 08:39 AM)
Is a 74 with a GA engine.
Cool, a 2.0!
Key will start the car, but not stop the car. Need to stall it to shut the engine off.
Electrical is bogeyed up somewhere. Power is feeding back through something (very possibly a light?) into the ignition switch circuitry.
Needs repairs to the inner wheelhouse on both sides. I've only seen the right side panels for sale. Does anyone sell the left sides or am I fabricating one?
If RD doesn't carry it, check with the dealer. There may be one somewhere in the supply line, and there are people out there sitting on NOS body panels as well.
Or get one from a donor car (that side usually isn't too bad) or fab it yourself.
Missing the engine lid/vent knob
The most common reason is that the threads stripped out of it, or off of the end of the cable. If Mikey isn't producing these, used from our classifieds is the best bet.
I looked underneath, and there is only 1 heat exchanger/heater box (driver's side). The other looks either like a header, or that the tin was removed from the heat exchanger. Is this normal?
It's an easy "fix" for a badly rotted heat exchanger wrapping. Real headers don't stay separate all the way back, so it is pretty certain that yours is just the stock pipes with the wrapping cut off on one side.
There is an aux. fan in the engine bay (driver's side) behind the seat that looks plumbed into the heat exchanger.
Normal. In 70-72, the fan was centrally mounted (more or less) and had two outlets, one running to the heat exchanger on each side. In 73-74, they moved the fan to the left side, changed it to single outlet, and only plumbed it to the left side exchanger. There was a cap that blocked off the right side one. In 75-76, they put a splitter on the outlet of the fan, and ran it to both exchangers again. The engine cooling fan pushes air through the exchangers while the engine is running, so the electric fan is just a booster, primarily for while you're at idle.
--DD
