$7.25 from Pelican parts
http://www.pelicanparts.com/cgi-bin/ksearc...-303-017-02-OEMYou may lose a drop or two tranny oil, since you
1. pull off the electric leads that insert into the reverse switch,
2. take out the reverse switch,
3. remove old pin
4. insert new pin
5. re install tranny switch
6. plug in electric leads. As easy and non-messy as you can get on the tranny
careful on lead removal, as 40 years of oil and heat may make the lead separate from the crimp bulb at the end of each lead, so use a pair of needle nose and try to grab at the barrel, rather than just tugging at the wire, don't ask me how I know
