QUOTE(dlkawashima @ Aug 7 2015, 08:35 AM)
I have a couple of tops, so I had a local shop (Yeaman's Auto Body) experiment with one. It was a painful process that took six months and at least four different attempts but the end result looks great, not quite perfect, but it's very close to the original finish.
The shop used a Wurth product and also a special gun from Wurth to achieve the finish. You could contact Scott Yeaman and see if he'll share the process ... he's in East Palo Alto, California.
Click to view attachment Wurth underbody shutz is the most common aftermarket way to get the proper texture for the top - as well as for the rockers & F & R valences & belly pans/wheel wells - for as close to the factory finish as possible.
No - the targa top was not a rough finished FG (molds were smooth so FG finish would be too), but a "heavy eggshell" applied with the same undercoating rock guard as on the belly pans & wheel wells, rockers & valences at the factory, the satin black over all but the bellies/wells - which were body color. .... & the "shoe polish" finish noted above is too shiny.
Top & rocker/valences finish was a satin to semi-flat finish - never shiny until someone polished it &/or it wore smooth over the years.
There are some older how to posts in Originality & History Forum on getting the finish if you search there - & the rockers/valances method would be about the same. IIRC Pat Garvey had one of the best ones.
... or take Dave's advice & call Marty!
Good Luck & Cheers Mate!
Tom T
