[quote name='timothy_nd28' date='Aug 8 2015, 11:03 AM' post='2220603']
Here's where I'm at
[/quote]
Thanks for the advise, this is a great option. The tub I bought came with 914 hubs that were already drilled for 5 lugs. At this point, not really sure which route to go, but I do know that I will scratch off the axle kit from the order list at Renegade.
That transmission mount looks pretty cool, is that what I should expect from Renegade, never seen a picture of it. That adapter plate looks pretty thick, was that made from Kennedy Adapters? Kennedy pretty much told me to screw off once they knew I was trying to mate a LS4 to a Boxster 6 speed. The LS4 has no provisions for a starter, same holds true for the Boxster transaxle. After some intense searching, I found a company that has mated these two before and only charges 1500 for the adapter plate, flywheel, pressure plate, clutch and starter. The LS4 seems pretty popular with the Fiero crowd, and has been even installed in a MGB! I also like the idea that this engine can disable 4 cylinders at freeway speeds to conserve fuel. This will be a fun project!
[/quote]
My engine is l33 which is aluminum 5.3 same as ls4 except I have 799 heads high comp pistons and cam.That adaptor is kennedy. The ls1 style starter does bolt up no problems.
The flywheel clutch package is pretty crazy :-)
