QUOTE(914Sixer @ Aug 7 2015, 09:33 PM)
Remove the door latch assembly from inside the door. Soak and clean 40 yrs of white grease off of it. Lube and reinstall.
Thanks for your response. But, isn't there a pull rod that connects the interior door actuator with the door latch? I can pull the interior door lever just fine; however, that does not translate into any action at the door latch.
