I'd appreciate any information and suggestions on my 1975 914 1.8L fuel system problems.
The car will start right up but will not idle or stay running without holding the throttle open. When I spray carb cleaner into the intake while running, the rpm's go up off of idle, leading me to believe it's running lean. The engine sounds smooth when holding the throttle open and the rpm's are up.
I've changed the fuel filter and the fuel. I think I've eliminated vacuum leaks or ignition as the source of the problem. The fuel pump runs and I can feel it pumping fuel, but not sure if it's working at full strength.
My thoughts at this point are that the fuel pump is not working properly or a problem with the fuel pressure regulator. I'm leaning to the fuel pump as the problem, but I may be way off base.
I'd welcome anyone's expertise on this issue.
Thanks!
