For those of you looking for a great front suspension upgrade for your 914, here it is......
Package includes:
- Bilstein HD struts with matched gas inserts. Both struts have been checked on a Porsche jig for correct spindle alignment and to ensure their tubes are straight. Struts are now media blasted and can be finished in Bilstein green or color of your choice.
- Excellent condition front hubs have been media blasted, VHT cleared and all stud threads were chased. The pair of hubs include new bearings, races and seals so your installation is easy. New rotor mounting hardware is also included (nuts, bolts, washers).
- New vented, Sport rotors from Sebro add to the stopping capability of this package without adding too much weight. They are standard '84 to '89 911 Carrera rotors that are 282.5mm OD and 24mm wide.
- Brembo Porsche brake calipers. These calipers are reconditioned four piston monoblocks that were original equipment on the Boxster. The calipers have pads the size of the legendary 930 Brembos yet they are lighter and superior in design to that generation caliper. Mounting adapters for the calipers are included. The caliper and rotor combination is a perfect fit for your original equipment wheels.
If you are interested in doing more:
- I can raise the spindles to your specification (+20 to +40mm).
- Add full gussets.
- Install bump steer kits.
Respond here, email or call for more information.
$2,500.00 plus shipping. Upgrades quoted on request.
a914guy@aol.com
(214) 796-2895 Cell
