QUOTE(marksteinhilber @ Aug 10 2015, 12:15 PM)
Check for play in the shifter itself and the connection to the shift rod in the tunnel. Could possibly be a worn cone screw at that connection or as described in the shifter mechanism itself.
Hey Mark, hope you're well, been a while since I've seen you at AX. Basically, every connection from the shifter all the way back to the transmission has been replaced. Even the shift fork that connects the shift rod to the shifter in the tunnel - this was replaced with the tangerine racing precision shift adjuster. The only slop now is in the shifter itself (or gear stick as us brits call it).
The precision shift adjuster has two holes it can be bolted to the shifter through. The upper is for a normal shift, the lower is for a 20% decreased short shift. I'm getting the side to side slop in the shifter no matter which hole I use.
Rhodyguy - off the top of my head, in 2nd the shifter has about half an inch play to the left and the same to the right. So I can basically waggle it side to side while it's in gear. I'll take a look for wear when I get home tonight.
I haven't had a chance to drive it and dial it in yet, so I'm not sure where the shift pattern is right now and how much I need to adjust it, which might help me figure out how much difference in feel there really is between 2nd and 4th.
Also, it could just be my expectations. I'm used to waggling a shifter in neutral and it self-righting back to the centre, and waggling it in any gear allowing a minimal amount of left to right movement, if any. Did the 914 shifter leave the factory doing that?
