Yes Dave, that would be the box below the cushion is in smooth black vinyl leatherette, like that used on your center consoles.
To clarify -
On the hinged tops/cushions - the underside should also be in the interior color of smooth leatherette vinyl, but with a small map pocket up under there.
Often the lesser upholstery resto shops & DAPOs leave that detail off when they recover them!
I'm not sure about what the earlier removable (non-hinged) 70-72 center cushion underside had on it, but if that's the type you're looking at, then maybe someone else can chime in!
Cheers!
Tom
