My 1.7 injection was running great and then wasn't. Starts first thing from cold. Idle sometimes steady as a rock and then drops off and dies. Then it is difficult to start again unless I wait at least half an hour or so. Ideas???.
914_teener
Aug 13 2015, 10:21 AM
Yes.
Check the MPS with a vacuum leak down test first.
Diaphragm could have cracked.
Then check back.
Bob L.
Aug 13 2015, 11:42 AM
Also check vacuum hoses for cracks or loose connections.
lennyhope
Aug 13 2015, 11:53 AM
QUOTE(Bob L. @ Aug 13 2015, 06:42 PM)
The thing is it runs and idles fine until you blip the throttle and it just splutters to a stop and then wont start again for a while.
BeatNavy
Aug 13 2015, 12:39 PM
Based on the limited info you provided, I can only suggest keeping the CHT in your lineup of "usual suspects" (if you haven't already eliminated that as a possibility). When it fails, or is failing, or when the wiring harness develops breaks (even if you can't see them), the car may start when cold then die quickly thereafter.
