gcrotvik
Aug 14 2015, 07:52 AM
Can I use the new 914/6 heat exchangers from Stoddard on a 74 2.7 motor in my 6 conversion? Do the OE exchangers for a 2.0 fit on a 2.7?
Thanks
Greg
Cairo94507
Aug 14 2015, 07:58 AM
Yes you can. However, I understand there may be fitment issues with the new heat exchangers. One of our members bought a set and discovered the issue when he went to install them. He alerted Stoddard and they were going to correct the problem. I would check that out thoroughly before you plop down $3K. But aside from that, they should be fine.
gcrotvik
Aug 14 2015, 08:06 AM
QUOTE(Cairo94507 @ Aug 14 2015, 06:58 AM)
Thank you!
SLITS
Aug 14 2015, 08:27 AM
I run them on a '76 2.7L. I have run them on a 2.4L MFI engine also (both are repaired used ones ... OEM.
The cost of them is outta sight.
GeorgeRud
Aug 14 2015, 05:04 PM
The originals fit fine on my 2.7.
Larry.Hubby
Aug 14 2015, 08:56 PM
The originals work fine up to 3.2 motors. Difficult as that may be to believe, dyno testing by Jerry Woods has shown only about a 5hp penalty vs stock from the small (1 3/8") primary tubes on the stock 914-6 HEs when used with a 3.2 motor, and mid-range response is actually improved. The Stoddard reproductions are better than the originals (or will be once they resolve the fitment issues) in two ways: the primary tubes are stainless instead of mild steel, and the tubes are larger (1.5" vs 1 3/8") and so are the same size as the factory HEs on the 3.0 and 3.2 motors. I know because I ordered a set too, and sent them back because they didn't fit, just like toolguy, but not before I measured the diameter of the primaries.
racerx9146
Aug 15 2015, 02:29 PM
Originals bolt right on my 3.6. I am sure it is not ideal I like heat in Winter and the torque is incredible! If am losing power it's not a lot.
Cairo94507
Aug 15 2015, 02:55 PM
Actually that makes me feel a lot better. I was concerned about putting stock heat exchangers on my 3,2 but if you are running them on a 3,6 I will be good to go for sure.
Perry Kiehl Clone
Aug 16 2015, 12:36 PM
The often referenced FI to carb 215hp 3.0 in Bruce Anderson's book was actually for a 914-6 and the exhaust used was factory 6 heat exchangers. They are designed really well.
