QUOTE(914Sixer @ Aug 16 2015, 01:31 PM)
You are right on the money. Take motor off and check rack movement. Most have 40 yr old white gum grease. Be EXTRA careful with little C-clip at the top of the stem.
Cheers 914sixer ,have close to full voltage there ,losing around 1 volt @ the motor so that not an issue I don't think?
Thanks also halfmoon,checked that and replaced fuse any way ,had around 12v there.
Found the outer gland nuts on the wiper cowl loose from when it was painted I guess,that made some differance.
Took off RH side wiper arm off and ran it faster,really good enough to think thats all it has on the second speed.
So wiper drive out? any clever tips on removal ?,first time for me,thanks.
