I have the skills but don't have the tools or the material to do this. I need a steel plate made with three holes in it so i can re-angle the clutch pulley for my header installation.
With the header on, the clutch cable rubs on the header. A custom plate between the clutch pulley housing and the transmission will enable me to rotate the housing slightly so the angle of the cable goes further down and gives some clearence to the header. Cable will be wrapped with fireproof sleeve.
Can anyone out there fabricate this? I will get exact measurements. The plate is small; 3"x 5" tops.
I have seen the other mount made that relocates the pulley horizontal but that will not work for mine.
I anticipate that more than just me may want one of these.
Can anyone out there punch this out?
