QUOTE(Dave_Darling @ Aug 17 2015, 08:17 AM)
First question: Do you have five-lug wheels?
Second question: How far apart are the two mounting bolt holes on the caliper?
Stock 914 parts should have mounting bolts that are 3" on-center apart. A common-ish mod to put 5-lug wheels on is to use 911 struts, some of which fit brakes that are 3.5" on-center apart. Hmm, though with the A or S struts you'd have brake rotors that are very thick and the stock calipers would not fit over at all. So I may be on the wrong track with this.
Still, if the bolts don't fit, it is probably because the bolt holes are a different distance apart. Measure and see what they are.
If you are using late calipers on an early strut (or early calipers on a late strut) the bolts will fit, but the caliper will be badly off-center on the rotor. That is what Stu is describing. But that doesn't seem to fit the description of "the bolts don't fit". So more info would be good.
--DD
Yeah, I talked to the mechanic and he said that the new one is a whole or or so longer than the old. And no, I dont have five lugs, but I sure wish I do!
